Jparkes43 329 #1 Posted July 26, 2014 As you may know i am currently building a 227-5 to make it faster than when it came out the factory but there is one thing i wold like to so but i have no idea how to take it off. help is greatly appreciated james Share this post Link to post Share on other sites
Jparkes43 329 #2 Posted July 26, 2014 oh guys i just check my manual and saw that it was a pin through the wheel that held it on so i tried tapping it out and trying to get it out with pliars but none worked so i am asking you guys the best way to do that as i don't want to break it thanks james Share this post Link to post Share on other sites
meadowfield 2,545 #3 Posted July 26, 2014 If you can get the whole wheel and shaft out then clamp it in a vice and knock the pin out with a drift. You have to get the pin out! Share this post Link to post Share on other sites
Jparkes43 329 #4 Posted July 26, 2014 that is an option but that would be a lot of work just to see what the shaft is like so il will try tomorrow with a bit more force james Share this post Link to post Share on other sites
tarcoleo 119 #5 Posted July 26, 2014 If you can get somebody to hold something heavy against the steering column just below the steering wheel like the head of a sledge, you will be able to nock the pin out with a drift without taking the column out. Just my theory. Share this post Link to post Share on other sites
Jparkes43 329 #6 Posted July 26, 2014 i will try that tomorrow, thank you for your help. james Share this post Link to post Share on other sites
Stormin 9,975 #7 Posted July 31, 2014 Good luck, James. I've been trying to get the pin out on my C-120 for days. It's rock solid, (been in since 1980) and shaft and wheel are off the machine. It's getting regular applications of penetrating fluid at the moment. Share this post Link to post Share on other sites
Jparkes43 329 #8 Posted July 31, 2014 Good luck, James. I've been trying to get the pin out on my C-120 for days. It's rock solid, (been in since 1980) and shaft and wheel are off the machine. It's getting regular applications of penetrating fluid at the moment. you story is exactly the same as mine although your slightly worse of as yours has been in there since 1980 and thankfully ive only got 24 years of rust!!! The penetrating fluid seems to help a little but not as much as i would hope/like james Share this post Link to post Share on other sites
rmaynard 14,888 #9 Posted July 31, 2014 (edited) The biggest problem is that with the steering wheels being made of plastic, when you try to back up the pin as you tap it out, the plastic hub will be damaged. I bought a cheap air hammer and a 1/4" pin punch. That's the one with a little on the end that fits into the center of the pin. Then the repetitious hammering of the air hammer moves the pin out without having to back it up. Then if the wheel is frozen to the shaft, the next part off the saga begins. Apparently the software here doesn't like my choice of words, so I replaced it with an image of the word. Edited July 31, 2014 by rmaynard 1 Share this post Link to post Share on other sites
Zeus55 38 #10 Posted July 31, 2014 (edited) Same problem with my 701 steering wheel. The pin is so hard to get out. I've started to clean the hole in the pin with a small drill and remove all dirt and rust. Then I'm applying a strong loose nut and let it work for a couple of days... I'll try then Edited July 31, 2014 by Zeus55 1 Share this post Link to post Share on other sites
Stormin 9,975 #11 Posted August 1, 2014 To save any more damage to the wheel, it was already cracked, I'm going to clean up the instrument panel in situ. I did think of cutting and sleeving then re welding the shaft but I don't I need to. Share this post Link to post Share on other sites
Charlie Smith 142 #12 Posted August 4, 2014 I've never actully looked at my steering wheel closely as in taking it off, If you haven't already got it off, could you not drill the old pin out, then when you're putting it back on, buy the right sized Clevis pin and r clip? Share this post Link to post Share on other sites
meadowfield 2,545 #13 Posted August 4, 2014 The pins are a rolled pin, made from a tight roll of spring steel. I doubt you could drill one out, you can try a smaller punch and see if the centre will break and push through first to relieve the pressure... Share this post Link to post Share on other sites
