oneroadkingman 53 #1 Posted July 25, 2014 hello< i needed to change out my 36 inch rd deck to my 48 inch sd deck and i can not get the belt to hook up to pto correct.the belt is to short.when changing from one size deck to a larger one do u need to change the belt to a bigger one also?? thanks Share this post Link to post Share on other sites
rmaynard 14,865 #2 Posted July 25, 2014 The short answer is yes, each deck has it's own belt requirement. 1 Share this post Link to post Share on other sites
oneroadkingman 53 #3 Posted July 26, 2014 Thank You Maynard I will check into the correct belt size then. Share this post Link to post Share on other sites
oneroadkingman 53 #4 Posted July 28, 2014 well i did some research and thought that a 107 in. would work,but it dosent its to big. .i think know that a 103 might do it. does anybody know if there is a chart that would tell me exactly what size to use..thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,488 #5 Posted July 28, 2014 Once you know the original belt number the sizes are on the last pages. Garry Share this post Link to post Share on other sites
oneroadkingman 53 #6 Posted July 29, 2014 ok Garry thanks for the info it takes a 1/2 x104.know ihave to fiqure out how to adjust the clutch? Share this post Link to post Share on other sites
