chev0545
smokin tractor
chev0545
just got this toro wh 268 w/ a 18hp kohler ohv engine.only has 270hrs on it.the guy said it was in storage for 5yrs.smoke coming out of exhaust,  carb,  & breather vent. doesn't seem to smoke at full throttle.any idea's?
KC9KAS
Too much oil?
Plugged crank-case breather?
Navig8r
Mouse (or other) nest material in exhaust burning off..... does it continue to smoke after being shut down?
chev0545
no nests, it does smoke after shut down
HorseFixer
I would give it a good sea Foam Treatment.
~Duke  :wh:
chev0545
it was a head gasket
KC9KAS
Thanks for letting us know what it took to fix it! :tools-wrench:
So many times a member will post a "problem" asking for help. Folks give their ideas for fixing the problem, but we never find out what helped! :handgestures-thumbdown:
Knowing the repair will assist in diagnosing future problems from the computer screen. :happy-bouncyyellow:
OK, I'm done..... :angry-soapbox:
HorseFixer
Did you discover why? Was there loose head bolts? Any signs of overheating?
~Duke  :wh:
chev0545
the original gaskets are paper thin on these kohler ohv.the one had pin hole's in it
