JoeM
WH 42 Snow Push Blade
JoeM
I had an old 42" snow blade that I got as an add on to a tractor deal and decided to modify it into a snow push blade. I watched a few YouTube vids on snow push equipment and figured I would make a mini version for a Wheel Horse. The side flaps float and worked better than expected. I tried it out on the last snow and it move about 5 times as much as an unaltered blade. Just thought I would share.
squonk
I   like it!  :thumbs: I'.ve been toying with the same idea only maybe using some kind of pin arrangement to make them come off easier for when you want a regular plow.
Edited by squonk
papaglide
Really nice. I wish that I had your fabbing skills!
  • Similar Content
    • neilevans1971
      By neilevans1971
      42in Snowthrower #79362 for sale
      You pick up, as I cannot deliver.
      Lot's of fun to clear a sidewalk in one pass or driveway in just a few.
      I have the manual, belt and attachment parts that go with it but are not pictured. All are in good working order.
    • Bill Winn
      By Bill Winn
      For sale. 1981 WH C-175 Kohler twin series 1
      1. Tractor has brand new ag tires all the way around, brand new seat, new points and condenser, new rear blade quick attach bracket, lights have been rewired with LEDs, it has a brand new lift cable and bracket,seat pan is from a 410... it's surface rusted but at least it isn't busted up like the oem plastic one, starts and runs but smokes a bit on startup if it's been sitting for months but she runs smooth and strong.
      2. Tiller is like new. It had been used only about once when I bought it and now it has been used 4 times more. Tines still have much of the factory paint on them.
      3. 42" mower deck works perfectly, 4. snow blade was/ is rough but I repaired it so it is quite functional,
      4. Brand new rear grader blade,
      5. Wheel Horse brand plow,
      6. Wheel Horse brand disc- I added a piece of motorgrader blade for a drag. I also welded a post to the top to hold weights,
      7. Wheel Horse brand cultivator,
      8. Home built furrower. (Makes good rows)
      The original Wheel Horse plow/disc/cultivator originally came as a modular kit and in order to use it the draw bar and clevis hitch had to be swapped back and forth. (big pain) I fabricated draw bars and hitches onto each piece so this is no longer necessary.
      I think this is a fair asking price at $2200 for all.
    • WH1618speed
      By WH1618speed
      1965 Wheel Horse 855 with 42" blade and chains
      Runs good
      Sheet metal is very straight, great candidate for restoration.
      Missing Belt guard
      Will sell tractor by itself for $500 without blade and chains
      Blade is straight and lots of cutting edge left... just a little rusty.
      Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
      I can also deliver to the big show in Arendtsville, PA... IF you prepay.
      Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
    • Joe Warren
      By Joe Warren
      New Old Stock Toro/Wheel Horse Blade Kit #117192
      This kit contains three # 116207 blades
      Diagonal length:               14”
      Blade width:                       2"
      Center hole:                       3/4” diameter
      Used On:                             42” Side Discharge Mower   (1989 - 1992)   Models:  05-42SY01, 05-42SY02, 05-42SY03, 05-42RY01, 78415, 38" Side Discharge Mower Model 05-38SY01
      $49 per kit which includes shipping within US lower 48
      Two kits available
      Thank you
      Joeww121@gmail.com
    • sfox17
      By sfox17
      Hello How much is a 79361 Ser. 5900 worth? it's in good shape. The only thing wrong is one impeller blade needs to be straightened. I'm just looking for a ball park figure if the blade was straightened or not. Thanks Sean
