pezsox
RJ 58 filter questions (oil bath & fuel)
pezsox
I am wondering how to get either of these filters out and how or even if I should replace them. One is for the oil bath filter and the other is for the glass sediment bowl filter on the bottom of the gas tank. Any help would be appreciated. Thanks
post-10744-0-46924500-1386868529_thumb.j
post-10744-0-98920200-1386868548_thumb.j
post-10744-0-77172800-1386868559_thumb.j
post-10744-0-89844900-1386868569_thumb.j
buckrancher
the gas filter screen will come out if you remove the bowl gasket but you can replace the hole filter unit for around 10 bucks
the air filter mesh about all you can do is clean it in solvent by soaking it
Brian
pezsox
can you just by the filter for the unit? The unit is perfectly fine, but man that gasket/filter look iffy
buckrancher
no longer made if your talking about the air filter if you want a new one watch e-bay one may come up someday
Brian
pezsox
I am planning on just cleaning the oil bath filter, I was more interested in the filter screen in the fuel apparatus
wallfish
pezsox
I couldn't  tell if that was an o ring or a gasket, so I didnt want to go prying the thing out of there to clean it. Thanks for the help
post-10744-0-01607100-1386952853_thumb.j
Edited by pezsox
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • clip
      By clip
      Wheel Horse RJ-58 with RMR-32 deck and a slot hitch cultivator for sale. I got this cleaned up, motor swapped from a giant old 3hp Briggs (got rid of the spacers the previous owner had under the hood) and rebuilt the mower deck with new bearings, bearing blocks and gear covers, found two sets of NOS blade tips, mowed the yard five or six times and it's ready to go to a new home. Found that the model/serial were hand-stamped on the frame alongside the tag. Weld-repaired some cracks on the RMR-32 and the slot hitch. I don't have the room or time to do a proper restoration. As it sits, it's a solid mowing machine that's ready to work for another 50 years.
      The good:
      Great running Predator 212cc, trimmed airbox and routed exhaust to work with hood
      Cleaned gas tank and new gas line/filter
      New shifter boot
      New belts
      Fresh grease in all fittings
      Flushed and fresh gear lube in transmission
      New bearings in RMR-32 spindles
      New bearing blocks for RMR-32 driveshaft
      Solid deck, very few if any rust spots
      NOS hi-lift blade tips less than a season old
      Additional set of NOS hi-lift blade tips
      Smooth-shifting transmission
      Original BFGoodrich/Firestone tires
      Tag/serial number still attached to frame
      Cultivator has been freed up and adjusts properly
      The not good:
      Weld-repaired front wheels
      Rear tire inner sidewalls starting to peel
      Hood has a few extra holes cut in
      No belt guards
      Right rear hub had a bolt driven into the key slot and stripped the threads - I removed it and cleaned up the keyslot, added another threaded hole and put a set screw and fresh key in. The hub has been shimmed on the shaft with brass stock to take up some slack left by the old bolt and shaft wallowing it out slightly.
    • Robert Concato
      By Robert Concato
      Hi I'm new to site. I am looking for a gas tank for an RJ 35 Tractor any help would be great thanks!
    • wh315-8
      By wh315-8
      Looking for the measurements for items #69 mounting bracket and #79 lifting rod. So that I could fabricate and be able to install on my RJ59. Any pics of the mounting bracket would be a big help.
    • Clay Dodson
      By Clay Dodson
      RAINES AUCTIONS **LIVE AUCTION SEPT 16TH @ 10:00 AM WITH PREVIEW FRIDAY 9:00-5:00 AND ON SATURDAY @ 8:00 AM UNTIL AUCTION TIME**   <CLICK HERE FOR PARTIAL CATALOG>      ^^PRE REGISTER NOW TO AVOID LONG LINES ON THE MORNING OF THE AUCTION.  CALL KATIE AT 540 775 3880, SHE WILL ISSUE YOU A BIDDERS NUMBER.  THEN JUST SHOW YOUR ID AND PICK UP YOUR BID CARD ON FRIDAY AFTERNOON OR SATURDAY MORNING^^           See below for 3 preview videos of the BIGGEST selection ever of Farm Tractors, Garden & Yard Tractors, Riding & Push Mowers, Implements, Bush Hogs, Finish Mowers, Chain Saws, Weed Eaters, Generators, Snow Blowers, Chippers, Tillers and tons MORE all SOLD ABSOLUTE RAIN OR SHINE!!!!    Including 80+ Wheel Horse Tractors, Wheel Horse Raider Models 10, 12, 211-4, 656, 416-8, C-160, Wheel Horse Charger Models 12, GT-14, A100, C160, D160, D200 w/blade, 310 B, 856, 317, 332, 854, 212-6, 211-5, 520-8, 211-3, C-120, Lawn Ranger,  Antique & Rare Tractors including David Bradley Suburbans, Panzer T707 & Chain Driven Bolens, John Deere Models 650, 110, 112 L, 70, 420, 214, 316, 317, 318, 160, 111, 116, 212, 216, 332, Massey Ferguson 135 Diesel, Economy Power Kings & Jim Dandy models 1614, 2414, 2418 & others, Ford, 2 Yanmar 1500 & 2000, Simplicity Models 725 w/blade, 9020, 6216, Baron 7014, 7114, 2210, 3414, 637, 3012, 3410, 728, 3415, 3314, 7116, 7117, 5116 Special, 6211, 9020, Early Speedex Chain Driven Tractor, Scarce Very Clean Pennsylvania Meteor Model 1010, Gravely, Allis Chalmers, Case, Turf Trac, Toro, Cub Cadet, Troy Bilt, Honda, Craftsman and many many others.    ***CLICK HERE FOR PREVIEW VIDEO #1***   ***PREVIEW VIDEO #2***   ****PREVIEW VIDEO #3***     ##LOAD OUT TERMS ARE AS FOLLOWS## THERE WILL BE AN INDEPENDENT PERSON LOADING OUT LARGE MOWERS & TRACTORS FOR $10 PER UNIT IF YOU NEED THAT SERVICE.  DUE TO THE LACK OF ROOM, THERE WILL BE *NO* LOADING USING LARGE EQUIPMENT UNTIL AFTER 2:00 PM. WE WILL SELL THE TRACTORS & EQUIPMENT IN THE FRONT AREA FIRST SO LOAD OUT CAN START ONCE WE ARE DONE WITH THAT AREA, ABOUT 2:00 PM.  YOU WILL ALSO BE ABLE TO LOAD OUT ALL DAY SUNDAY, MONDAY AND TUESDAY THE 19TH UNTIL 5:00 PM.  AT THAT POINT, ANY ITEMS LEFT BEHIND WILL BE SALVAGED UNLESS YOU HAVE PRIOR PERMISSION FROM THE AUCTIONEERS, RAY RAINES OR CLAY DODSON.   ^^SPECIAL RATES AT THE ZION CROSSROADS BEST WESTERN (WHICH IS ONLY 3 MILES FROM THE SALE) IF YOU MENTION RAINES AUCTIONS^^  CALL 540 832 1700 AND REMEMBER TO MENTION RAINES AUCTIONS TO SAVE$$$~     **CLICK HERE FOR HOTEL ACCOMMODATIONS SUGGESTIONS**    Mark your calendar now for this Colossal auction that is not to be missed~    Ray Raines Auctions VA License #3395
