Toadster
C 141 Snowblower?
Toadster
Trying to find a snowblower for my C 141 automatic, just located one with a model # 6-7211 and was wondering if anyone knows if it will work on this unit
without too much work.   Many Thanks
KATO
That looks like a blower for older tractors pre attachamatic.
not sure what you would have to do to make it fit. Heres a attachment interchange list
and Welcome to :rs:
WH Interchange 1955-2000.pdf
Irv
6-7211 is model years 1962-72. Different pully and attaching settups. Probably a pain to make work on the c series. You need one with model #66-42st01 thru 86-42st04 .
wingrider
I have converted that blower to fit to the attach a matic with a newer mounting bracket that will fit on a C series tractor. Also changed
the pulley on the blower to the next size smaller so it will be easier to get the belt off the blower.
Works great and spins the auger faster, its on a C160 and really blows.
Wingrider
47JDG
I have one also that has been converted over to a newer attach a matic. You just need to change the mounting bracket is all to make it work. Changing the belt pulley also sounds like a good idea. I am looking forward to using mine.
