AMC RULES
Tell your girl, good job...the trans looks really good.   :handgestures-thumbsup:
zanepetty
It really is. Half the joy is posting it on here.I was.t to do the best job I can! I jistboughtmygun at harbor freight by the way! I'm excited. If you don't come to the show this year I might just have to make a trip to your house to show you this stuff, steve ;) haha. And I will, Craig! I'm eh hmm, not for sure exactly how much she really did bit anyways...:)
Edited by zanepetty
speedyleedy
We all need a gal like that to sand on are tractor's ! :eusa-think:  Tell she did a great job........... :)
zanepetty
I sure will. She's a good one for sure. I couldn't ask for any better. I got some more goodies today from harbor freight. This gun feels surprisingly good in my hand and doesn't rattle or clank or feel like junk. I took the advice of all you guys on here and bought the $15 gun tonight. I can't wait to use it. I also bought cleaning brushes, extra gun filters, and a regulator. I was extremely happy.
post-11334-0-08173600-1384392872_thumb.j
Edited by zanepetty
zanepetty
I primed a bunch of little pieces today. Heres the starter. I used the grinder and cup brush on it as well. I taped up the Delco tag. I'll take it back off when its time for clear. I think it will look nice with clear over it
post-11334-0-59538700-1384482052_thumb.j
Edited by zanepetty
kudzu3
Lookin' good Zane. Got home today, thanks for the muffler, and it was good meeting you. The pictures are nice.
zanepetty
You too, tommy! I hope it works well for you!
zanepetty
Here's what I got done today. I block sanded my dash tower starting with 320 and then 400 to make sure I got AAAAL the orange peel and gloss leaving it nice and matte for my red :) as for the rest of the parts here, I scotch padded them with red then with the super fine grey one, INCLUDING In between gear teeth and motor fins. Also before I primed them? I used a white rag and wiped them down with mineral spirits until the rag came out clean. It may be a little much but I want to make sure I protect my tractor for years to come plus make it look nice!
post-11334-0-01122800-1384562714_thumb.j
Edited by zanepetty
speedyleedy
Look's great so your new spray worked good for you .
zanepetty
Well I didn't use it to spray that. I just sanded and scotch padded today. I used a friends gun for primer.
zanepetty
Should I paint my carb and fuel pump? I don't know if it will mess them up or not. I know I would have to plug up the holes if I did.
kudzu3
Good morning! I painted the fuel pump on my present restore, it seemed to have been painted at the factory. I'm not painting the carb, just shining it up a little. I rebuilt the carb on a d 160 once, it had been painted already, so I painted it again. I don't see what it could possibly hurt, I believe some were painted at the factory and some weren't. I guess it's just a matter of personal preference. Just my observations, I'm sure someone here will know the real answer.
rmaynard
I don't paint either as long as they clean up good. Otherwise, if I do paint them, I use a bright aluminum color that is not affected by gasoline, something like Eastwood Carb Renew.
zanepetty
OK. I'll try to clean them up . They would look good painted though. Thanks guys.
kudzu3
Just a thought, I like to use flitz metal polish on any unpainted stuff, it really brings out the shine and adds a special touch, especially to brass. You can use a medium soft brush on the hard to reach places. I get those small cheap paint brushes form home depot for this kind of stuff. As I said, just a thought.
zanepetty
Ya. That's a great idea, tommy. I'll try that.
zanepetty
Finally got my hood ready for red. It had some dings, the grille was a little bent and it had two holes that I had welded up. Not rust holes. Just two holes. I have no idea how they got there, but I fixed all of it and put some etch primer then a few coats of high-build 2k urethane primer, then wet sanded all with 400. I'm pretty proud of the way it turned out
post-11334-0-07226500-1385070294_thumb.j
post-11334-0-20352200-1385070368_thumb.j
post-11334-0-96847700-1385070425_thumb.j
Edited by zanepetty
kudzu3
You should be proud, looks real nice. :)
zanepetty
Thanks, tommy. I want to see your progress on yours!
Ken B
Looking good!
zanepetty
Thanks!
stevasaurus
That hood likes really nice Zane... :)
zanepetty
Thanks friend!
zanepetty
Here's the battery box after I had a local welding shop weld a new one on. They did a really good job.
post-11334-0-97180700-1385321119_thumb.j
post-11334-0-69611400-1385321135_thumb.j
kudzu3
Looks nice! Looks like you're gonna have one of the nicest tractors around. Your patience and attention to detail will pay off, can't wait to see the final results.
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • jmack
      By jmack
      I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
