zanepetty
leaking carb
zanepetty
Hey again everyone. I've gotten SO much done on my tractor thanks to this site and most of all my new friend stevasaurus. What a great guy. Anyway my carb bowl is leaking around the bolt. I tried a small rubber washer but it stretched around the bolt. Should I try a bigger one?
MalMac
More than likely the bowl has small hairline cracks in it around the bolt, the cracks are not really visible until you put pressure on it from tightening the bolts. You will need to just replace the bowl.
zanepetty
Oh OK I gotcha. So can I buy a bowl new or will I have to look on eBay?
zanepetty
I found one. Thanks for the help!
buckrancher
besure to use a new red fiber washer under the bolt
brian
zanepetty
OK I'll pick one of those up too. Thanks , Brian.
Edited by zanepetty
zanepetty
Where can I get one of those washers?
buckrancher
they are part of the rebuild kit your local toro dealer may have them
zanepetty
OK. I called my Kohler dealer and they said that the kits were obsolete?
953 nut
Sellers on ebay have lots of carb kits to offer at rather fair prices, just check the feedback before you buy.
:USA:
tunahead72
Try somewhere else...
NAPA
OPEEngines.com
PartsTree.com
JacksSmallEngines.com
Check RedSquare Links (under Wheel Horse Reference) for some other ideas.
Edited by tunahead72
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
