Kelly
Wh wheel weights
Kelly
I have a pair of rear wheel weights for a WH that look like these but mine have 4 mounting holes, and do not have the cut out for a valve stem, are these WH or other?? I know they probably had other company's make their weights.
C-Series14
Same as I have, I have the matching front and rear and 99 percent sure mine are WH. I will look tomorrow and see if there is a part number on mine...
pond195520032003
Kelly, they are the same, just the ones with the valve stem notch could be used on the D series and the others cant :USA: i have a pair without the notch (see allachments picture section) look under wheel weights as i and someone else posted pics! either seat can be used on all the other 12" wheels but the inside of the D wheels are much larger :omg: :banghead:
