zanepetty
leaky rearend pulley
I've had my wheel horse 753 for about a week now and hasn't leaked a drop of anything. Previous owner said it didn't leak for him either. I walked to the garage today and noticed a couple of drops under the rear end!:( they came from the pulley on the left side. Any advice on how to fix this? Thanks
Zane
Remove the brake drum and replace the oil seal. Toro part number 100863 or NAPA NOS9815.
Awesome. I'm going to probably do the axle seals too. I've never done that before on anything. Is it really hard to do?
Changing the seals is easy. Pulling the hubs to do so can be tough.
Hi Zane,  in your first message you said no leaks except around the brake drum shaft?
Axle seals aren't leaking?  Why change them?
Use a hammer on what?  Rear hubs?  ummmm, NO, not unless you want to be buying new hubs.
and possibly knock the C clip off the end of the axle on the inside of the transmission, making it necessary to open the transmission.
OK good to know. My friend said it was fine. I didn't think so. The right axle seal looks wet. There's not a drop running down it but I just thought it might b a good idea while I'm at it. Maybe not?
I dunno... for just a little bit of 'seepage' like that, I don't think I would bother... I guess it depends on how 'AR' you are!  :ychain:  and how much ambition you have!
I personally would probably 'shake er down' for a few months and see how it goes, then make a list of stuff you want to do with it and set up a 'priority list' of what NEEDS to be done, and what you WANT to do.
Strangest thing. I moved and and let it sit all day and not one drop of oil is under it in the new spot..oh well I guess she fixed herself!:D
And yes I do agree with "shaking her down" for a bit. Thanks guys. Im new so I have a lot to learn.
Strangest thing. I moved and and let it sit all day and not one drop of oil is under it in the new spot..oh well I guess she fixed herself! :D
Or she is low on oil...
If you do decide to change out the axles seals...they are the same numbers as the brake shaft seal.  If you need to add oil, use 90wt. :)
No. I don't believe so. There were only three little drops under it and I just changed the oil 2 days before. I added 1 1/2 quarts of 80-90 wt oil. I plan to run it for a bit then flush it and put new in just to get things cleaned out well. And thank you for the part numbers. That's a big help. I'm going to my toro dealer today:)
In as few words as possible, heat, PB Blaster, and a good hub puller. No hammers. Lots of patience. Do a search for "hub removal".
Good luck. It can be done.  :)
A pick and maybe a pair of needlenose pliers.  If you do a search for the words axle seal replacement you'll get several topics that might help you out on this... and your next question that you haven't asked yet...about how to seat the new ones. :ychain:
OK so I found out how to smooth up and clean up the axle before I put the seal in. Is that what you mean by seating?
I tapped the seal all the way in (which was a little more than flush) and it STILL leaks just the same if not more than before. PLEASE HELP!:(((
Do you have up and down movement on the axle? In and out movement of about 1/8" is normal, but any movement front to back or up and down is an indication that the bearings are shot. If this is the case, new seals will do nothing to stop the leakage, and the transmission has to be opened up to replace the bearings.
For what it's worth I'll add my .02 on installing seals - I found over the years,  this overall easy procedure to be very tricky - one little missed burr - going over the key slot etc and your seal will nick and leak  - I've installed some 2 -3 times before I got it ....
My  personal seal install procedure :
1) Clean all burrs off axle or shaft
2) Tape key-way slot - ( key-ways will cut/nick seals ) I use a small piece of electric tape
3) I then wrap shaft with a small amount of plastic wrap  from the kitchen being careful not to wrap where the seal seats ( getting the wrap out from under the seal seated is not fun ) - this is my insurance in case I missed a bur .
4) I use 3 in 1 oil to wet the outside of plastic wrap
5) Same 3 in 1 oil on seal itself where it meets axle/shaft
6) Gently and evenly  push seal on shaft to case- larger seals I gently seat with the appropriate size black iron pipe ( nipple ) with end cap on tapping end and gently ( very important to drive seal in level and even )  tap seal in with my 8-10 oz  ball pien hammer
Over the years I've taken seals to lowe's and matched them up with the appropriate size pipe nipple for driving, think I have 5 or 6 pieces in the tool box, some smaller ones ( seals ) couldn't find a nipple that would work - these were installed with the widest punch in my box going around the seal and slowly/gently  tapping it in in until it seats .
For whatever reason, maybe it's just luck - I find the 3 in 1 oil best for installing seals - knock on wood I haven't had a leaker since I started using it .
Hope this helps -  I never drive seals " dry "
This is actually very close to how I installed my seals. But unfortunately I do have a little bit of up and down motion. So I guess I'll need to open it up. I've never done something like this so I don't know if its a job I can do or one I should try to get a toro dealer to do..?
If you know how to turn a ratchet and wrench, you can do it! Watch stevasaurus' how to videos pinned at the top in the trans forum
Via Tapatalk 4
I just hung up with a toro dealer and he said that the case had to be pressed and they're really hard to get opened and to be pressed he said they had to be heated and stuff:( he also told me most of the gears would have to come out so it really scared me. Is this true?
  • Similar Content
    • By lak1965
      New used fork from ebay shifter assembly with spring and bearings. Tomorrow I will upload a picture of a tool we made to reinstall the fork keeping spring and ball in place.
    • By 'garGuyPaulie
      Hello all - I have a 1990 312-8 that recently started being a pain to shift, and eventually it stopped shifting into 1st and reverse and was hard to get into 2nd and 3rd. After looking at some posts on here I discovered the possibility that a loose shifter could cause this problem. My shifter definitely had a lot of play in it so I proceeded to pull the seat, rear plate and shift plate off the tractor so I could get to the area where the shifter goes into the transmission. I removed the shifter, reseated it and got the dog head screw lined up in the shifter donut and was hoping that would fix the issue, but after getting it all reassembled and trying to shift even into 2nd or 3rd the shifter, while not as sloppy, now just turns side to side - taking it back out and inspecting the shifter I have discovered that the pin which holds the donut in place on the shifter has sheered and the donut is now able to free spin on the shaft. Not too much of a problem as I plan on just pressing the old pin out and replacing, however I am concerned that the ball on the end of the shifter seems to be getting pretty flattened off on the left and right sides of the ball. I tried looking up a replacement on Toro and several other parts websites but I can't find one anywhere - I can get the boot, everyone has those, but no shifter. My question is, does anyone know where I might be able to find a new shifter and more important, is a little flattening on the ball anything to worry about?
      Also, with the shifter out, looking down the hole my transmission looks like it's full of mud! Definitely doesn't look like the gear oil I put in it - anyone know what could be causing the transmission gear oil to be sludging up like that?
    • By JZilla024
      Hello everyone!
      I recently inherited my grandpa's
      Wheel Horse 753. I remember it running before his health declined about 15 years ago. My intentions are just to get it running and do a mild restoration, it'll stay in the family.
      Without further ado, here it is!
      Having a hard time with pictures due to no phone service at my shop. I'll be sure to update soon.
    • By mikeystones
      Has anyone tried to link two trans. Together
    • By Rkeller
      Can anybody help with a bearing kit for asundstran hydro trans tag # 90.  1137 on a d180
