RasmusA
No spark - K181 - WH800 - hoping for your help :)
RasmusA
Hi there
I have a WH800 im trying to start up, after 10-15 years in a barn.
I know it was running when it was placed there, but now i cant get a spark on it :(
Engine turns fine (new bat)
I have tried to replace the Coil - still no spark.
I have tried to replace the ignition switch - still no spark
I have replaced the plug - still no spark
I have removed the flywheel. Everything looks nice, but how can I measure that it is?
Magnets are fine, but how about the stators? (Blue on this engine)
Just under the ignition switch there is a rectifier-regulator. If this one is dead (and how do i measure that?) can my spark disapere there?
Please share your wisdom - i want my old WH back on the grass :)
(Used to drive it at my grandparrents farmwhen i was a kid)
rmaynard
You don't need anything but a battery, good coil, points, and spark plug to get ignition. Stator, regulator and all that are superfluous to having a spark.
Be sure that the points are opening and closing on each revolution, and that the contacts are clean. Make sure you have a good condenser. The ignition needs 12 volts to the coil and the points make and break the circuit to create the high voltage at the tip of the plug. As long as the battery is good and you have a flow of 12 volt from it through the switch to the coil you should get spark.
The other stuff mentioned is for charging.
Edited by rmaynard
RasmusA
Let me apologize for the (very) late response.
The WH has been sitting in the corner of my garage, not working and it should be ashamed of it self...
Status is after reading Maynards fine suggestion:
 - Coil have been replaced to another 12V coil
 - Points are braking fine and they are clean
 - There's 12.8V on the + on the coil
 - The battery is on 12,8V
Still no spark!!!
How do i check the condenser?
And will the spark be missing, if the condenser is dead?
I have 20-30 new condensers for 12V systems (for cars) - is there any luck that i can use one of them?
The reason that i have had a pause with the WH is, that i have spend a lot of time on my other red classic, a Volvo P1800S from 1964.
Imported from Oregon and now a running project here :)
wallfish
Yes, you can use one of those condensers and it should be connected to the - side of the coil, plus the body of the condenser needs to be grounded. There should be a wire from the points to the - side of the coil as well. MAke sure there are no breaks in that wire.
Sorry if you already know this stuff but without being there, I need to guess.
RasmusA
Thank you wallfish - i will try a new condenser then.
squonk
How do you know there is no spark. Do you have a spark tester? Sometimes using a plug laying on the head will fool you. Also you can put a 12v test light on the neg side of the coil. It should flash when cranking. If it doesn't the coil won't produce high voltage
RasmusA
Well - i have tested with the plug on the cylinder head, and turned of the light in the garage (in the evening - dark night here in Denmark)
Would'n that normally show me a spark, if it's working?
squonk
If the plug is not grounded well you will get no spark
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
