jnelkie 11 #1 Posted July 24, 2013 im looking for size or part number if any one has it and how hard are they to replace. Share this post Link to post Share on other sites
groundhog47 347 #2 Posted July 24, 2013 If in reading post your unit is 91-160501, Toro lists the seal as 6449. I too am concerned with a nontear down seal change on mine, and got seals at local bearing supply only to find I already had a pair in stash. Hopefully we'll both learn a in frame removal/replacement. Share this post Link to post Share on other sites
jnelkie 11 #3 Posted July 24, 2013 Thanks, I just flushed the the oil in the case due to some water getting in it due to a crack on the dipstick tube and now one seal is leaking. Its never a dull moment playing with the tracktor but I'd never give it up. Share this post Link to post Share on other sites
pfrederi 17,146 #4 Posted July 24, 2013 (edited) CR SKF # 11124 Good luck getting the hubs off they can be a real bear!! Note how I bent the steel tubes I used to make the puller Edited July 24, 2013 by pfrederi Share this post Link to post Share on other sites
jnelkie 11 #5 Posted July 25, 2013 got the hub off and learned to use the biggest gear puller you have because the small ones break. Share this post Link to post Share on other sites
