Retired Wrencher
E-Bay tractor
Retired Wrencher
:USA::wh: Here are a few pictures of the 606 I pick up today. It looks like it is all original in 47 year shape. this will be a summer project. I need a 607 may turn this into one but ???? this real easy to work on 1 wire from the key. No safety switches on this unit. Ohh Check out the original Belt??? and did this tractor come with a HH60 engine. I always thought these where H60`s  I hope u enjoy the pictures.   Gary      B....ooohhh Mike this is another Ct. Tractor....            606001_zps1a16b3c9.jpg     th_606004_zps3c8e3589.jpg    th_606006_zpsbf99fa2a.jpg    606016_zps93a00073.jpg 606015_zps87e627c5.jpg
stevasaurus
Nice short frame...my paper work says it came with a H60-75118D...so maybe not original engine. :)
Retired Wrencher
Thanks That is what I thought Steve  They must have put in a short block in and put all the original shrouding on Buy the way how is the old Galaxy running these days. still a nice car.don`t let Gas Monkeys find this one out?? Gary    B....
Sparky
Hmmmm.......do I need to dial 911 you over-the-state-line-tractor-rustler!
  Personally I would never rustle a   :liar: tractor from another state.... :eusa-whistle:  .
  Mike........
stevasaurus
The Ford Custom is running great (Galaxy body)...my son just took it for a long weekend to South Carolina from Illinois...no problems. :)
Sparky...if anyone believes that...stand on your head.  Hey, everything is upside down. :ychain:
AMC RULES
  Mike........
I believe, when  :wh: 's are leaving the state of Connecticut...
is legally the only way you can do it      :teasing-poke:
Edited by MAYHEM '13
squonk
Every one with Tecky's need to start notching their frames every time they replace the Tek with another!! :ychain: :ychain: :) :) :bow-blue: :bow-blue:
KC9KAS
I am looking at information that says.....606 1966 4 speed, Tecumseh HH60-105014A....Just what his ID plate says.....So what is right??
Retired Wrencher
Well Guys what ever the engine is we now for sure it is a W/Horse with the id tag that says T606 on  still not sure what to do with it but time will tell. Very possible just shine it and enjoy it or trade it for a 607.
Jake Kuhn
Nice looking tractor! My 657 has a tag that says hh60. But I am pretty sure it has a aluminum block? Not really sure.
Jake
stevasaurus
KC is right...that is the right tag and the right engine.  It looks like I was looking at the 605...dang small print...sorry, my mistake. :bow-blue:
squonk
The bandanna got in your eye!
Retired Wrencher
:USA::wh:  Hey thanks guys It is nice to know that it is the write engine in the right tractor. NOTHING LIKE ORIGINAL . But not sure of the 657. Here are some pic`s of that I think they swap out this engine look close at the decals. Click on them to make larger.            657comeshome008_zps9a8c9482.jpg    th_657gettingthere015_zpsc5978dcf.jpg this is the Engine  id plate     th_606016_zps93a00073.jpg
squonk
I thought XL meant Extra Load! :ychain: :ychain: :)
stevasaurus
Looks like the only difference is the last letter of the spec number...shows a "B" and yours is "C".  I have some old books that have the early Tecumseh-Lauson engine information in them, but I have never seen where you could break down the spec numbers.  The "B" or "C" could mean a lot or not much of anything.  It may be possible that engine did come with that tractor.  I had a HT55C-3088P in my 502 and did a lot of research on that engine...not much out there, but is probably the same block as yours..Seems like you have some Teckys, have you ever found out anything with the numbers? :)
BTW, when I click on one of your pictures, it takes me to your photobucket folder for these pics.  Absolutely awesome pictures of your horses in that folder. :)  WOW
Retired Wrencher
BTW, when I click on one of your pictures, it takes me to your photo bucket folder for these pics.  Absolutely awesome pictures of your horses in that folder. :)  WOW
Thanks Steve I am not that good with the computers so this is the only way I know how to do it. I am bit old fashion and do not like changes. So thanks for the info. I guess I will just enjoy what I have. Gary     B.................
  • Similar Content
    • Steelspinner76
      By Steelspinner76
      Just picked up a wheel horse 606 looks to be pretty complete someone has put a different cover on it and mounted a snow blower style electric start. but everything looks solid and the engine turns over. looking forward to bringing it back.  Any things i should look out for on this model
      Weak points wear points ect Here is a pic as it is now just arriving home this morning
    • Bttatro
      By Bttatro
      I have seen these 36" gear driven decks on short frame tractors and lawn rangers alike.  And I happen to have one off a lawn ranger, but have a 606 I'd like to put it on.   Is this possible?   Or do I need some substantial modifications?
      Thanks!
    • Bttatro
      By Bttatro
      The title pretty much sums it up.  I picked up lawn ranger? carcass for $20 in hopes the deck will work on my 606.  It looks like they both use the attach-o-mattic, but I could be wrong.
      Any help is appreciated.  Also if anyone needs parts let me know. It doesn't have an engine, fuel tank, hood, front rims, or probably other things too.  (Maybe I should just list what it does have, might be shorter)
      Thanks!
    • cschannuth
      By cschannuth
      My old 606 rat is what I use for chores and pulling in the summer and I plan to use it to push snow in the winter. With the AGs with fluid and weights it was pretty rough on the yard when I would pull the spreader and aerator making relatively quick, tight turns. Sorta silly but I came up with some 520 wheels and cheap Chinese turfs to use in the summer.  I was gonna put the rear hub caps back on but I kinda like he deep dish look for now. The AGs and caps will go back on when the snow blade does.
    • Team70R
      By Team70R
      Two of my 606's both have battery trays and electric start. Both with factory 606 tags. Now my question is why not just get a 656 from the dealer ship? Was it cheaper to get a 606 and upgrade the starter? Both have the proper key ignition switches as well.
