fourwheels0 191 #1 Posted June 23, 2013 i got this thinking it was the solid link for a dozer blade on my 1973 16 auto but i can't see how it would work. did i get the wrong piece?. it seems to be an inch or so offset from where it mount's to the blade. what is it and or what do i need?. it's the bottom piece in the pic. it's flat with a pin at each end. it has the number 8172 on it. Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted June 23, 2013 its the right part it hooks right on the rock shaft and on the plow i have a couple of them and have used them on a bunch of differant tractors but to make it work right you have to take the j bar that lifts your deck off Share this post Link to post Share on other sites
fourwheels0 191 #3 Posted June 23, 2013 ok i saw that it might work but the j-bar was in the way. i didn't know you have to remove it. thanks jdog. Share this post Link to post Share on other sites
jdog_kustoms 82 #4 Posted June 23, 2013 u can make it fit with the j bar but it binds up some times and wont let the plow come the hole way up Share this post Link to post Share on other sites
fourwheels0 191 #5 Posted June 24, 2013 sure enough i popped off the j bar and it went on no problem. thanks again. Share this post Link to post Share on other sites
