  • ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoticons maximum are allowed.
    ×   Your link has been automatically embedded.   Display as a link instead
    ×   Your previous content has been restored.   Clear editor
    ×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By JoeB
      Good morning,
      This is my first post.  Several years ago I bought a c120 auto and have used it to mow and snowplow with great success.  The other night in the midst of a snow storm I was in a hurry to get going, and didn't check the oil and didn't give the engine enough time to warm up.  Result seems to be a broken connecting rod, since it cranks now much faster than it did before and won't start when it was a terrific starter before.
      So I'm looking for ways to repair the damage I've done.  I really love the tractor, comparing it to modern ones that feel like tin foil convinces me that I want to fix this iron horse.
      I am in southwest Michigan, and looking for help.
      thanks in advance.
    • By Npostusa
      Hi Just bought my 312 this spring when we moved into a new home with two acres of land.  Love the wheel horse, but I am not even sure if I have to change a oil filter and for that matter where the filter or oil plug would be - any guidance would be appreciated.  Put a little marvel mystery oil in the gas, and just started it up for a few, but want to change the oil for the spring. Any guidance on where to start would be greatly appreciated.
    • By lak1965
      Like many others on this site I decided Sunday it was time to install the New / Used Cab I bought in spring with the help of my brother. I never had it installed so was not sure what I was in for but it was assembled when I received it. First Picture was install rear frame under seat. It was at this point I went to RedSquare and downloaded the manual and printed it out for reference.
      Next install front of frame. Had to remove some brackets that mounted to the dash and drill a hole one each side of foot boards to mount the inside brace. That is a forward swept axle and tires you see sitting in the shed. Next spring project to mount that on the old C-160. Also I will change the way the lights are mounted on the hardtop.
      And finally the finished product. I was surprised at how well it fit and how easy it was to install. Let it Snow, Let it snow , Let it snow!
    • By cabin4me
      I have a 79 C-111 that I pulled a running 11hp briggs and stratton engine from and also a front push blade.  I am looking to sale both.  Push blade 200 Engine 100
      I also have the original mowing deck for this mower.  I am looking for a WH pull behind tiller attachment, maybe trade?
