Xjchief
Just picked up my first rj
jusjeepn
I may be all wet here, but dont you have a steel grille shell screwed in to a smooth cast iron weight? The hood should be two seperate pieces welded together to make one. This pic shows how it should look unbolted from the tractor. Yours appears to be two seperate pieces that attaches together at the weight.
buckrancher
I find it highly unlikely an average person could melt down 85lbs of iron and pour it into a mold and make this. But even if it is not a true wheelhorse factory part it is still a one off which is very cool and if it turns out to be a true part then it will still be a one off that noone knew existed either way its a win in my book
What you have here is someone took the hood to a foundery and they made a sand mold of the front of the hood and cast it then took the hood a part and used the cast weight as the front of the hood instead
of the sheet metal front
not a bad idea as you need to remove the weight to get the original hood off
Brian
Xjchief
I think the tranz pulley is on backwards too.
Where are you going to put the gas tank? :scratchead:
thanks for that i pulled it off and it was on backwards the set screw threads were broken also so i am on the hunt for a new one are there any options for a new one or is original the only way to go
TT
An original pulley seems to fit the best.
Pulley #1611 was used on a bunch of the three speeds and should be easy to find.
jusjeepn
I'd like to see how it's mounted. I find it highly unlikely that one machine screw or even a 3/8" bolt would hold 85lbs in place for very long.
Xjchief
Update on tractor turned around seat spring found broken trans pulley rerouted belt made a custom exhaust.
Xjchief
post-9395-0-38785900-1361491932_thumb.jp
Jake Kuhn
Looking nice! :handgestures-thumbup:
AMC RULES
Any :wh: updates yet...how's it going?
Xjchief
Finished it couple of weeks ago
post-9395-0-31281600-1366492134_thumb.jp
AMC RULES
:woohoo: ...and it turned out really nice too.   :handgestures-thumbsup:
Terry M
I have to also say that your restore job has turned out really nice!!! :handgestures-thumbupright:
Jake Kuhn
Very nice! Can't wait to see how the decals make it look!
Xjchief
Yea my cousin is an artist and he is going to either airbrush or paint them on. Something a little different ya know
AMC RULES
Humm, can't wait to see how the artwork turns out.   :popcorn:
VinsRJ
Very nice work!
