Torino
Where does this go?
Torino
C-175. Was working the tractor and noticed this on the ground. I think it is from the tractor because of the red paint. Sure is big though. Don't know where it would go.
glgrumpy
Front axle center pin lock-nut?
toolmaker40
mule drive cover ? on pto front?
Duff
What Toolmaker said......
Duff :thumbs:
rmaynard
Dittos on the mule drive cover.
ericj
yea the mule cover. the nut that holds the cover and pulleys
eric
Torino
It is for the mule drive cover. I do not have one so so I even need the nut?
mrocket49
Yes, you need that nut on because it keeps the idler pulleys on the shaft.
Kelly
It's supposed to hold the cover, spacer, outer pulley spacer and inner pulley on, but most the pulleys are rusted to the shaft, my FIL, called me one day asking if I had a pulley, so I just took a mule drive over to him, he said he was mowing and the pulley shot off out in to the pond when he was mowing, and had no clue why??? but then he said he never had a cover or nut on it for years, but today it let loose.
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • drewd
      By drewd
      Hi All,
      I have what I believe is a Commando 800 but would like to confirm model and year.  Tag reads Model # 1 0100 6; Serial # 790336. Have had it for years (bought from original owner) and want to clean it up some.
      Thanks!
