  • ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoticons maximum are allowed.
    ×   Your link has been automatically embedded.   Display as a link instead
    ×   Your previous content has been restored.   Clear editor
    ×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By Goldann520
      I'm back @WV Hillbilly, @ACman, @horsenewbee. I'm once again a wh owner. You guys were right. Only this time it's only a 1990 312-8 classic. But hey, I gave $50 bucks for it!!!!! Kohler magnum runs like  a champ and has a nice 42" rear discharge deck on it. Paint not too bad, pics to come. Of couse has normal hackery for this price, but im back in the game ! Gotta get back to work now, talk later. Goldann520
    • By Sarge
      Fast question ...
      Per the IPL for the 6-1141 and 6-1131 54" & 56" blades - how is everyone pinning the rear blade lock arms so they can't unlock the blade ? I've ran into problems with this thing before wanting to unlock itself and drop the blade half off the tractor. It seems when back dragging rough pavement, especially if I back into a snow bank the thing is moving those locks out of position and allowing the frame to drop off. The only reason it stays at least somewhat under the D is the lift arm , but getting it back into position is no fun due to the weight of this thing and especially out in the snow/cold weather. Last time I had to drag the thing back to a clear area so I could wrestle it back into position, lift the frame and lock it again. I did wire them shut for now, but don't trust it and I use it to back drag quite a bit on rough areas I don't want to ram the cutting edge against and risk damaging the rear axle differential or anything else. Mine has been rebuilt with a new cutting edge of 1055HC and the frame is highly beefed up - most of it is now boxed in and the thing has gained nearly 50lbs of steel. It cuts great, almost too good but that random dropping it off is starting to irritate me - need some ideas here...
      The smaller 42" and other frames lock from the other direction - so to speak. The brackets are also drilled to accept large hair pin cotters to keep those locks in place - I see no way the bigger blade frame is designed for that, unless I'm missing something ?
    • By Npostusa
      Hi Just bought my 312 this spring when we moved into a new home with two acres of land.  Love the wheel horse, but I am not even sure if I have to change a oil filter and for that matter where the filter or oil plug would be - any guidance would be appreciated.  Put a little marvel mystery oil in the gas, and just started it up for a few, but want to change the oil for the spring. Any guidance on where to start would be greatly appreciated.
    • By lak1965
      Like many others on this site I decided Sunday it was time to install the New / Used Cab I bought in spring with the help of my brother. I never had it installed so was not sure what I was in for but it was assembled when I received it. First Picture was install rear frame under seat. It was at this point I went to RedSquare and downloaded the manual and printed it out for reference.
      Next install front of frame. Had to remove some brackets that mounted to the dash and drill a hole one each side of foot boards to mount the inside brace. That is a forward swept axle and tires you see sitting in the shed. Next spring project to mount that on the old C-160. Also I will change the way the lights are mounted on the hardtop.
      And finally the finished product. I was surprised at how well it fit and how easy it was to install. Let it Snow, Let it snow , Let it snow!
    • By Seacrestbf
      I have a D 200 and my sons have been cutting the lawn this summer and nerver check th oil and the seized the motor. I freed the motor up and it runs fine until there is a load. I checked the Compression  and I have one dead hole. ;-(   it broke my heart. I have a Mower, tiller, and snow thrower.
      Any Advise? Should I buy a motor? Or rebuild or scrap?? I liked the machine. But I dont want to dump a ton of money into it if it is questionable. I am not sure if it is a Kohler or Onan??  Any thoughts
      Thank you
      Brian Foley
