stevasaurus
How a Transmission Works...video
SUBURBANS & RJ 58/59 TRANSMISSION CROSS OVER CHART FOR WH #5003 and #5010 TRANSMISSIONS
DESCRIPTION..............................................................WH #......................VENDOR..........QUANTITY...........SIZE
BRONZE BEARING (AXLE)..........................................1503.......................CB-1618-12..........2..................1" X 1 1/8" X 1 1/2"
BRONZE BEARING (DIFFERENTIAL HOUSING)..........1517.......................CB-2224-14..........2..................1 3/8" X 1 1/2" X 1 7/16"
INPUT SHAFT & OUT END OF BRAKE SHAFT.............1519........................S8K ground..........4..................3/4" X 1 5/8" X 5/16"
CLUSTER GEAR SHAFT & 11/44 GEAR BASE............1502........................NICE 412-35........3..................3/4" X 1 5/8" X 3/8"
INPUT GEAR NEEDLE BEARING.................................1518........................B-108...................1..................5/8" X 15/16" X 1/2"
BRONZE BEARINGS (CLUSTER GEAR SHAFT............1504.......................EP-1214-12..........2..................3/4" X 7/8" X 3/4"
BRAKE SHAFT (NEEDLE) IF YOU HAVE THIS............1508.......................B-1212.................1..................3/4" X 1" X 3/4"
SEALS AXLE (FROM TORO ONLY)..(CAP)...................1257.......................83-2840...............2
SEALS INPUT SHAFT & BRAKE SHAFT (BALL BRNG)..1234......................741643 timken......2
SEAL BRAKE SHAFT (IF NEEDLE BRNG).....................1303......................7410 skf................1
Edited by stevasaurus
So Steve, what I gathered from that last video is this, regardless whether on not it's the early or later trans...
before you open one up, you must confirm that you have a pair? :beer:
Edited by TWENTYHORSETWIN
Here is a short video concerning the replacement differential that they sent out for the 5003 and 5010 transmissions. This particular differential has the bolt on bull gear to the differential housing and is talked about in the manual on page 12. click the video...easier to watch then to explain... :)
Another great video from Jurassic Park Productions. :ychain:
Really nice Steve. :thumbs:
:hilarious:  Great Video Steve! Bob made me spill my coffee.
