Hydro
Which twin should I consider?
I've been thinking about changing up my Kohler 16 to a V twin. The 16 runs great but I still would like more power to drive my 2 stage blower. I have been looking at the Briggs Vanguard, Honda and Kohler. I see Kawasaki also has some engines in this class. Obviously I need the right crank dimensions, I have to stay within a certain crank height for the belt guard and I have overall clearance to consider.
I would appreciate any suggestions or experience anyone has to offer. I do not want to use an Onan. My intention is likely to put the 16 back in the 416-8 keeping it original and selling off the 14 Kohler that came out of the original 314H I started out with.
Thanks
Thanks
I would go with either a Kohler Command or a Kawasaki twin. If you have the $$ by all means pony up and buy a Kohler Command EFI (fuel injected) engine!
Almost all commercial mowers now a days have kawasaki and kohler twins, only a few have Briggs engines and if they do they are 30+HP
The Briggs Vanguard Twin is a good choice and several small engine suppliers make a Wheelhorse drop in kit using the Vanguard.
TT, (Terry), has one on a tractor he uses and I saw another Vanguard on a members tractor not too long ago. The Vanguard is a pretty good motor. We used a "community Log Splitter" with a Vanguad on it for over 10 years with no issues what so ever. And it is sadly abused!
Humm...I don't know, Mary Kate or Ashley? :eusa-think:
The Kohler twins? :ychain:
Try to get or download actual power curves of the engines you are considering. The reality is an 18-20 HP V-Twin won't end up giving you a whole heck of a lot more to work with than the M16/K341. I do have some re-power experience with Honda GX610/620's and Briggs (Diahatsu) Vanguards and they are both among the best small air cooled engines made. The Kohler Command is excellent too, but not many places sell them as re-power kits (Kohler doesn't like doing that, for warranty reasons as they don't know the application) so any special fabrication for fitting there would be up to you. But the 18-20 HP versions of most V-twins available won't run circles around the K341/M16, you have to go up more in HP, which can be bigger physical size and higher price tag.
-Mark-
I was thinking 22-24 HP and I had not considered fuel injection. I doubt I would spend that much extra. The engines I was looking at were in the $1400 range. My first thought was the Vanguard but looking for the experience here first. I also need to know what to expect with the change over.
Thanks for the replies so far.
I have seen the Robin-Suburhu engine at 25 hp. not sure if it would fit. I think some RS members have used it. would a Diesel work better for a monster 2 stage blower vs gasoline??
I mentioned a diesel when he bought parts, doesn't want one. They do stink, make a lot of noise, but haven't had any situations to really work the motor. If we ever get snow this winter maybe the plow will make it work. Biggest Kohler I've had was only a 14, and mowing a field it did good, but then so does my ranger with a 13 horse....
What model Wheel Horse are you going to put the V-Twin in.
It's a 314H with 520 front end, steering and rear wheels. Last year I switched it up to a 16 Single. I love the old cast iron singles and it does a great job but my first pass with the blower is 300 feet and even taking it slow with the 16, it was working pretty hard. I miss the smoothness of a twin so have been thinking about doing this. Thought I would ask you guys for your thoughts.
Littleredrider is right, I really don't want a diesel. The ones I have seen really belch a lot of smoke and they are noisey. I spend a couple of hours in the seat mowing so something smooth and quiet like the Onan...(did I say that???) is what I am hoping for.
16, 18, 21 and 23 HP Briggs & Stratton Vanguard are the smallest. The big block Vanguards are a lot larger. I put a 18 HP Vanguard on a 1977 C-120. I raised the Vanguard 3/4" to get it at the right height with a couple of 1/2" flats and a 3/8" plate. I checked the Honda and Kohler V-Twins and they were too large to fit on my C-120. You have more room on yours but I would measure carefully.
Here a picture of mine. You can see there isn't any room left with the crank shaft in the original location.
I have to think a 23 would do it. R U saying the blocks change size after that?
Gary
Quit playing games and get serious!!! I think you should go the route of a kubota 4x4 with a loader and 3pt blower. You'll be done in record time!
Then we're gaurenteed no snow this year.
hey gary,if the honda will fit id go that route,i have a 13 honda on one of the girls and its very powerful,reliable and easy to get parts for,but i never need any,i own about a dozen small engines and the hondas are very,very good motors,i see the 24 horse advertized to fit in the 520,but ive actually never seen it,good luck and let us know what you find out,up here in the great white north im not totally sold on deisels,i own one buy if its real cold out which happens up here all the time they are a pain to start
The 20 hp ONAN has plenty of power for the 2 stage blower and should be reliable with the proper maintenance and care.
As far as I am concerned nothing runs and sounds as good as the ONAN.
If ONAN is not an option, then other options that I would consider include the older opposed twin cylinder K and M series Kohlers in the 17 to 24 hp range. You could also have your 16 modified to produce a lot more power. You could check with someone like Brian Miller to see if that is a viable option and what the cost would be. I am a purist and I would try to keep my wheel horse all wheel horse.
"i own one (diesel) but if its real cold out which happens up here all the time they are a pain to start"
I have 1985 diesel Mercedes cars and discovered that proper valve adjustment is the key to easy starting in the winter, at least for my diesel engines. They will start immediately at zero degrees with no block heater.
When I was stationed up there, I bought a magnetic block heater from Canadian tire. Even with 20/50 in the pan, heated it right up and started without pumping that crap out of it. That good be an option, but magnets don't stick to aluminum very well tho. Break out the duct tape!!!!
My tractor is garaged so the cold weather starting is not an issue.
Yes Jack I agree the Onans have a great sound and are powerful.
A 18 through 25hp command will fit right in, I have one in a 300 series We made our own mounts. Wasn't hard
Duane
The 23 Vanguard is length 12.52" width 16.02" height is 17.68". The 25 Vanguard is length 14.92" width 19.53" height 28.54" according to the Brigg & Stratton site.
There is a huge differences between the single cylinders and twin cylinder hondas. The twin cylinder hondas are not nearly as good as their single cylinder counter parts. There is a reason why you do not see many many twin cylinder hondas on commercial grade equipment. When they break I have seen that crankshafts snap, and they are also overheat as the flywheel is not that big and does not provide adequate cooling. This is where Kohler and Kawasaki reign supreme. However the briggs big block vtwins are actually made by toyota and are great engines. Again I would go the route of a kohler, but people do go the route of a briggs as they are cheaper.
I am partial to Kohler, but I'd heard the Vanguard was a good engine too and of course so is the Kawasaki. CRE 1992 thanks for the heads up on the Honda. I was not aware of this issue until this post.
Thanks everyone for your help. Baerpath that sounds like what I am looking for. Crank shaft dimensions are the same and the belt guard lines up. Making up a piece of plate for the motor mount does not sound like an issue. What HP did you go with?
The Kohler Command sounds like a good choice especially the fuel injected version which would eliminate the carburetor problems with the fuels containing ethanol.
Except for the strong possibility that 10 or 15 years from now you could run in to problems with the electronics involved for the fuel system, and of course all the special FI parts will be "obsolete." Kawasaki had troubles with their EFI systems when the ethanol fuels first started hitting the market, so no fuel system is totally immune to problems in the future. Handa is still sticking it out with carbs.
-Mark-
  • Similar Content
    • By Hydro
      I recently bought a 1994 tall chute single stage snow thrower, model 79360.  I have replaced the chain, both idler sprockets, both idler pulleys and one jack shaft bearing on the chain side.  The auger is strait and the bearings are smooth.  It runs quietly.  I have it mounted on my 314H powered by a Kohler M16.  I am shearing the pulley key on the jack shaft.  It has happened twice now.  The first time it threw the set screw so I thought it was a matter that the screw was not tight enough.  Toro shows one screw although the pulley is drilled and tapped for two.  I was careful I thought when I positioned and tightened that screw.  After the first time, 20 minutes running, I added the second screw.  I also noticed the pulley has some wobble to it so I used some shim stock in order that there would be no play between the shaft and the pulley.   I ran it for about 20 minutes again and noticed both screws were loose so I used Loctite 242.  I let that sit for about 30 minutes and went out again.  In about 20 minutes I sheared the new key right off with a portion of it in the keyway of the pulley.  The shaft is clear of the key but has been scored some.
      My driveway is paved.   I was plowing before and built up some snow banks.  The first time I sheared the key, the thrower was mainly resting on the scraper blade and I was just removing snow from the driveway, I thought I might have jammed it with some ice.  The second time I raised the thrower to give it clearance so there was about 3/8†between the blade and the runners which I adjusted.
      I ease the machine into snow and creep along.  I do not ram it into snow banks.  I’ve seen videos of these things working really well.  Mine was blowing snow beautifully but something is not right.  Is it the fit between the pulley and the jackshaft?   Why would Loctite not hold the set screws? What is wrong with my machine or what I’m doing wrong?
      I have to suspect there is a weak point where something will give or the belt will just slip.  My belt is new and has the correct Toro Part number.  It fits the way I have seen them mounted so I doubt that has any part of what is happening.
      I would appreciate your thoughts.
      Thanks
      Gary
    • By Hydro
      I've been reading through various chain & bearing repair posts regarding the snow thrower.  I have just acquired a 1994.  The auger, jack shaft bearings and drive sprocket are in good shape.  The blower needs idler pulleys, a chain and the inside sprockets.  The auger sprocket rotates with about a 1/4" of wobble and the teeth are getting sharp. Is it normal for the auger sprocket to be off a little when manufactured?   The auger itself runs true.  Not sure how far to go with the rebuild as I know the auger sprocket would have to be re-done at a machine shop.  Here are a couple of pictures of the sprocket teeth.  What do you think?
      Thanks for your time.
    • By Martin
      trying to determine whether i have a good trans or not and have a question or more.
      i have an eaton 1100 in a rolling chassis that i want to test to see if its working well enough to justify using in a new tractor rebuild. i hooked it up to my 1848 pto with a longer mower belt to test it out. oil looks very clean so i left it and i know i need to get the correct filter on there, but for now its staying until i see some light at the end of the tunnel.
      just did a quick test tonight to see if i could at least get the lift to work. success on the first pull of the lever. hydro pump seems very quiet and no leaking or damp areas either. i worked the lift up and down from one extent to the other and it worked as good as any nice working lift i have. so I'm happy so far, now the questions......
      to test the drive I'm going to get it up off the ground and see if i can get the wheels to turn in either direction. i want to run it this way for quite a while until i can get some raising of oil temp.
      is putting weight on the lift going to change anything as far as a test goes? i figure if it goes up and down, is quiet doing so and doesn't leak, I'm 99 % there....
      is there any way to check to see if it is loosing pressure when it gets warmer?
      can a gauge be hooked up and is this easy enough to do?
      is it even worth finding out the pressures? what will having them tell me?
      is this a good enough way to test the whole hydro system? i think it will tell me at least if its working and if there are any leaks. i don't have a working engine that i can just throw in there to drive it around without puling one of my old starter gen motors from an unrestored 1277. i know this is probably the best way, drive it and get it nice and hot to be sure. i could swap it out from one of the other 1100s but then i got to deal with hoses etc and not really interested in pulling apart good working systems and opening other cans of worms.
      while it was running, and over the noise of the engine in the 1848, the pump seemed to be very quiet, quieter than the other 2 1100 tractors are. both of the other 1100s work well and aside from one having a leak in the lift, they both are leak free.
      ao at this stage i am happy with how things are going. just wondering if there was some expert opinions to help me on my way with some ideas.....
      thanks in advance for any input, fire away guys.....
    • By FZR
      Does anyone know where I can get a Routing Diagram for an LT-1100 3-Speed Drive Belt.  I'm looking for the routing diagram for the drive belt that runs from the engine to the transmission.  Any help would be appreciated.
