tommy3horse
C 160 hydro axel seals
tommy3horse
Hello Fellas;
My Dad called me about his 75 C160 tonite. Seems its bee sitting for most of the summer due to no rain at his place. Anyway, he said both axels are leaking and left small puddles under each. He asked me to look into repairing/replacing the seals. I have done one on my '76 C120 and it took a long time to get the old seal out. seems these have wide rubber-like seals and they are a challenge to remove.
Does anyone have a good method for removing the seals...other that digging them out with a pick...which took 2 hours to do on the C120?
Thanks alot,
Tom
Kelly
The hydro seals are wider, at least the orig. seals are the new ones are much thinner, I take them out with a thin small tip flat screw driver that i have made the tip thin like a small chisel, them punch it in at the edge of the seal near the trans housing, i do this in 3 or 4 spots trying not to push the seal to far in as you make the seal smaller it will come out with a little prying after you get a hole punched in it and the sides pushed inwards. I just did a set on a hydro it took about 15 min. to do both seals in and out after the hubs were off.
MalMac
I usually use a small pick but I have used small wood or sheet metal screws. Take the small screw and insert it into a small hole that you would make with a pick or small nail. Gently screw the screw into the seal being very careful not to get into the axel and marr it up. After the screw is in leaving it out some you can used pliers to pull on the screw. I have put used two screws on opposite sides to help get the seal out. But before you go to all that trouble try a pick first.
tommy3horse
thanks Kelly, do you have a seal part number. Napa or Toro dealer?
Thanx,
Tom
tommy3horse
Thanks to Bob Maynard's thread on the hydro parts breakdown, I found the Toro part number: 6449. Is this the seal?
Tom
specialwheelhorse
Don't know how this will work yet but I put two of the thin ones in where the old style thick seals were.
JIM In TEXAS
tommy3horse
Thanks, Jim, I never thought of that.
Tom
Kelly
if you put two seals on one side fill the gap between them with grease or the seal will run dry and burn up, it could in a worst case wear a groove in the axle, with no oil to lube it.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
