jonsteffen
pulling tires
jonsteffen
yes or no question and reason for answer,what would be better to run tubes in the rear tires or not
dennist
I did read Yes, so you can run lower pressure.
baerpath
Depends if there loaded yes, if just air in them then no.
We run 14 inch wide alum rims with Carlsile and Firestone 26x12 Usually around 5 psi(hard tracks) to 8psi (soft tracks) Never rolled a bead on any of the pullers all the way down to 2 psi on slimey tracks.
The tube won't push the sides of the tire down as much as the center
Duane
jonsteffen
Duane
thanks you two by the way baerpath i want to pick your brain for some tips and tricks in the pulling world for wheel horse tractors
stephan07
13 wide alum wheels no tubes here best combo i have used. they may be for sale if your interested.
jonsteffen
i am going to run 23x10.5x12's with steel rims with 23x11x12 rims so would i use tubes or not
