behunted
Tom from Belgium
behunted
hi everyone,
i'm Tom i live in a small town called Werchter, some off u may know it from the festival Rock Werchter
i'm 26years old and have a Wheel Horse C-120 bought when i was 14. The lawn shop revised it, so almost everything would work, but they didn't do a good job so i've started to do it myself...
Taking apart was easy but the electrical plan is a bit harder then i guessed, my old Citroën is easier...
AMC RULES
:WRS:
Tom...lets see some pictures of that C-120 when you can. :popcorn:
Sounds like you've owned it a long time. :scratchead:
behunted
yeah, my dad bought it for me because we had a small toro lawnmower but because the work was a bit too tough for it it had to be replaced, and we saw the WH standing at a lokal garage so we tought why not, and 2weeks later my old man surprised me with it...
bowtiebutler956
:WRS: Tom! The C-120 is a great machine, and I'm with Craig :wwp: ! Feel free to ask any questions you might have, we're always happy to help a fellow :wh: lover around here. :thumbs:
Matt :flags-texas:
Jake Kuhn
:WRS: I have a c120 and really like it. Haven't gotten to try out mowing with it yet but I am sure it would do a great job. Jake
Sparky
:WRS:
Mike.....
pmackellow
Hi Tom, welcome to Redsquare, plenty of help and knowledge on here !!
Anglo Traction
Hi Tom in :bflag: . :text-welcomeconfetti: to :rs:. As mentioned , if you need any help, just ask away.
If you can post the Model Number of your C-120 sometime (as well as Pics), we can point you to any Manuals you may need.
farmer
:text-welcomeconfetti: Tom from Belgium....... the home of :wh: in Europe :)
meadowfield
Hey Tom,
welcome to the club...
Have fun :D
Lars
Hey Tom
welcome to :rs:
WH Raider10
Hi Tom,
Good to have another Belgium member on the forum! My wheelhorse addiction also started when I was 14. If you ever need any help or maybe parts, feel free to ask as I live not that far from you.
Groetjes,
Pieter-Jan
neil
welcome to REDSQUARE Tom
you are amongst friends and very knowledgable people that should be able to help you get your c120 up and running again
behunted
A great machine to mow, even on hills like 30° and more, it feels a bit strange at first but once you've done it you'll get used to it
behunted
:WRS:
here you go
Stigian
Hi Tom, welcome to Redsquare. A more knowledgeable bunch of Wh freaks you won't find anywhere else :)
Bobie01
Hello from Luxembourg
nice Horse
electrical part isn't that hard I had also problems whit it but I had draw a plan by my self an redo the hole cabels an it works
good luck
wh1257
nice tractor ik denk alleen dat dait geen c-120 is maar een ander type
behunted
dit komt van de Toro partsviewer-site
Model # Serial Range Year ProductName
1-0353 None
None 1974 C-120 8-Speed
wh1257
ja sorry maar ik vind dat hij eeen beetje op raider model lijkt
AMC RULES
Nice looking :wh: tractor Tom, thanks for sharing your picts with :rs:
behunted
ik ken het raider-model alleen van naam maar ergens logisch dat ze op elkaar gelijken want ik geloof als ik me niet vergis dat de C-120 de opvolger is van de Raider 12
Anglo Traction
You have the Same Model and Year as the one I'm currently rebuilding. Could you tell me your Serial number please ?.
behunted
model 1-0353
Serial 135393
What's your's?
Anglo Traction
model 1-0353
Serial 135393
What's your's?
Serial 135117. Pretty close. My ID Tag is badly scratched and damaged. I need to find a replacement.
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
    • drewd
      By drewd
      Hi All,
      I have what I believe is a Commando 800 but would like to confirm model and year.  Tag reads Model # 1 0100 6; Serial # 790336. Have had it for years (bought from original owner) and want to clean it up some.
      Thanks!
