BairleaFarm
c160 loader
BairleaFarm
Anyone put a loader on a c160? Im sure they have but cant seem to find a thread on it? If you know where pictures are hiding please let me know.
Thanks
David
Nick
This tractor was at the 2003 PA show. If not a C-160 its close and has 26-12-12 tires and a KW loader.
This is also from 2003. Its a C-160 with WHeel Horse loader.
BairleaFarm
Do they use a hydrostatic drive or and separate pump to run the hydrolics?
Nick
I believe all loaders used on Wheel Horse tractors use a seperate pump. Most newer loaders mounted the pump on the loaders subframe but some had it on the side of the tractor frame or in front.
KyBlue
The second C160 pic posted you can see the pump stickin out kinda..
Nick
This picture shows the pump placement on an Ark loader just behind the PTO. The KW pump would be on the loader sub frame just below the PTO.
Found an old picture of the Ranger. Pump is mounted much the same as a factory KW setup would be. Just direct drive no clutch. B)
C-Series14
1979 C-161 8-speed with a 1979 WH FEL...On the back is a 1977 18 Cu. Ft. dump cart...BIG cart!
