AETD
B&S up and down in revs?
AETD
Can anyone tell me what is the problem when the engine runs like this.
(my neighbours murray with 12Hp B&S)
with lever low the enige runs smooth.
with lever high the revs starts to go up and down.
i allready cleaned the carb
te right arm (governor?) is pushing the throttle up and down.
youtube vid.
http://www.youtube.com/watch?v=aaJssLyJMJw&feature=plcp
TT
Have you tried adjusting the main jet needle? It's the one that points straight down out of the bottom of the float bowl nut.
AETD
Jep i did, when i turn that open (now it is about 1 and 1/2 turn open) from 2 it starts shooting flames true the exhaust when rev up and back to idle. ;-)
spark plug have the right color so i think mixture is good.
when i hold the arm i can feel it pushing.when u put a small screwdriver inbitween, it runs normal... I'm starthing to think the governor have a problem.
no wthe engine have not enough revs/power to mow.
riding is just possible but it's like riding a camel. (lol)
Rooster
Governor spring needs replaced is a common cause of that.
AETD
New governor spring did the job.
thanks
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
