JMW
Engine Dimensions
JMW
This might be a dumb question but here it goes.I'm putting a 12hp kohler in a c160 with a manual trans.Are these the same size (physically) as the original? If so does anyone know what the size of the original engine pulley would be? I would like to use a factory length belt. Thanks JIM
can whlvr
as long as the motor was from a wheelhorse,its a direct fit dimensionally,wiring could need a little changeing,the engine pulley for a manual is 4 inches outside and its for a 5/8 belt as long as the engine is from around the same year,if its from a 1978-1984 it sits on the cradle,so you will need a cradle or a plate,but its the same size block
baerpath
You will be fine as your engine was from a Raider12. Basically the same as a C160, Pully should be correct along with the belt size.
Duane
Don1977
The K 241, k 301, k 321, and the K 341 are the same dimensions on the out side and crank shaft location.
JMW
Thanks for the info guys!
Jim
