Calebintn
How do you bench test a egine?
Calebintn
Guys my 854 has some real wiring issues but I dont want do the rewire until after the restore.
Is there a way to direct wire the coil so I can test run the engine before I start the restore? :woohoo:
Save Old Iron
a jumper wire from the battery (+) terminal to the ignition coil (+)
and
a jumper from the battery (-) terminal to the case of the engine
will make it possible to activate the ignition system without any further connections.
Save Old Iron
and of course remember to disconnect the power to the coil when you are finished :woohoo:
Calebintn
Thank you
