MaineDad
K301 Oil Seals
MaineDad
Guys:
Reassembling the K301 and I pushed the oil seals in too far. I ended up having to pick them out and ruining them. So, can I get these at Napa? If so, does anyone have the part numbers for Napa?
TT
I have this info in my notes:
Front seal 7-04002
Rear seal 7-04003
I use nothing but OEM seals, so I have no clue if the above info is correct.
shorts
take the seals to the parts store and match them up, NAPA should be able to look up the right parts with the Kohler engine id info,or the numbers stamped on the seals should be able to be interchanged
KB9LOR
Guys:
Do not have the NAPA numbers but here are the OEM numbers:
Magneto Side #47-032-06s
PTO Side #47-032-07s
MaineDad
TT's Napa parts number were correct. They have been purchased and installed. One neat trick I discovered was that a caulking tube makes a good seal installer :woohoo:
Thanks for the help guys!
