wh1257
wheel horse tractor elektrical problem
wh1257
hello I have a problem with my raider 12 when I turn the key for him to run, then bolt it but when I release the key then is he still I do not recall where it may be who can help me
:):hide: :WRS:
catman81056
Not really sure what you're saying.
wh1257
normally start to turn the key and then let him go and he stays running but when I release the key then is he simply stopped
:hide:
TT
Sounds like it's time for a new ignition switch. :hide:
wh1257
I have replaced it are on an entirely new
TT
It must not be the correct switch then.
rmaynard
Vincent,
If you have a multi-meter, check to make sure that you have 12 volts at the (+) side of the coil when you turn the key to ON. When you turn the key to START, the 12 volts should still be there, and when you release the key, you should still have 12 volts at the coil. If you don't, then you either have the switch wired wrong or the new switch is bad.
