clintonnut
Voltage regulator woes..
clintonnut
I do not have a single regulator out of 4 or 6 that work. Most of them just one day didn't put a charge on the meter. I would clean the contacts and still nothing. These are the delco remy s/g regulators.
Charlie
MikesRJ
Did you check the ground from the regulator case to the engine? Try a wire and two alligator clips connected between a regulator cooling fins (clean and area) and a good engine ground point. See if that makes a difference.
sorekiwi
He's talking starter/generator regulators Mike.
They do still need to be grounded I think. Seems like one out of 4 should work though, are you sure you havent got a bad generator or wire?
MikesRJ
:thumbs:
Gene_S
What is the output of the generator to your regulator Charlie?
