meadowfield
C-101 steady progress
farmer
Mark,
Look at it this way, you now know which part on the westwood which is least likely to ever break. :thumbs: :thumbs:
meadowfield
Managed to finally get the hood painted last weekend after a few weeks in the tank and then lots of filler to fill the tiny pit marks.
looking all nice and shiny
Some of the fleet ! my trusty 79' Dixon ZTR
mark
Horse'n Around
Wow, it really turned out great. It makes me want to go into the dungeon/cellar/garage and work on mine :thumbs:
John
neil
looking really nice Mark, when you gonna put some of your own decals on it, also your light lens that you made.
meadowfield
just waiting for paint to fully dry, then decals will go on - need to add wiring for front lights, mine didn't come with lights...
WH854
Great Job Mark :thumbs::wh:
Chas
Anglo Traction
Looking Good Mark!. Is that your next project in the Trailer? :thumbs: .
JimD
Very nice! :thumbs:
repairman
sharp :thumbs: :wh:
meadowfield
thats my 74 raider...
was rolling on all fours before I donated the gearbox to my dad...
Not sure whether to re-assemble or combine with another non-runner if I can find one!
Quite like the idea of a hybrid along the line you are doing.
How does Raider 800, Range-a-matic, C-Raider, Raider-101 sound? :wh:
repairman
I like Raider Range-A-Matic :thumbs:
HunterdonNJ
Great job! Love your stone wall as well.
Jonas
meadowfield
Today I applied the decals !
I'm really pleased with how it turned out, just the front light wiring to do now
meadowfield
and the engine ones too !
wheeledhorseman
:thumbs: Engine looks so good! I'm beginning to think I should have spent more time achieving the same finish on the engine of my C-120. I was looking at mine today and trying to puzzle out the correct routing for the ignition suppy wire which at present wanders across the top like yours. Is this how they were?
meadowfield
Ahh. The wire ran through a clip along the top edge, but I unclipped it to apply the decals.
I am going to add 12" of wire in and run it under the cowl alongside the fuel pipe then it's practically hidden.
wheeledhorseman
Interesting, I fixed the fuel pipe back to the cowl today and decided that the ign cable must have originally run that way but somewhere along the line had got shortened. :thumbs: I'm puzzled why the designers chose to take it across the top, surely not to save on a few inches of cable? I think I'll opt for the long route too - may not be original but to my mind a better solution.
meadowfield
So ashamed was I at my disturbingly red spark plug :thumbs:
that it is all nice and shiny now! :wh:
I have just added 10 inch to the coil wire and run it under the cowl along with the choke and fuel pipe. Much neater...
mark
Anglo Traction
I also found it strange they started routing the Cable over the Shrouds (on the 74 C-120). It is routed down behind the Bearing Plate and Blower Housing, then 'Zip Tied' to the Fuel inlet on the Pump on my 72 Raider. I'll do the same as Mark, it's much tidier
n1defan
:thumbs: That is a nice looking tractor Mark. Keep up the good work.
wheeledhorseman
A partially painted plug could be more accurate than you think if trying to achieve a 'factory finish'. I am (sadly) old enough to remember the garden machinery my father bought new during the 60s and 70s. The 1960s Suffolk 4-stroke mower came with a partially painted spark plug as did the 19 inch flymo with 2-stroke Tecumseh which replaced it in the early 70s.
The plugs had obviously been inserted during engine assembly and before painting which makes sense as the hole would have to be blanked off with something to prevent paint entering the cylinder. In each case most of the plug insulator had been masked off so its possible Kohlers were painted like this too. Does anyone in the States remember?
I sometimes now can't remember where I put a part down only a few minutes ago :thumbs: but have a photographic memory for things that fascinated me as a kid. Must have been destined to restore old things :wh: .
meadowfield
I sometimes now can't remember where I put a part down only a few minutes ago :thumbs: but have a photographic memory for things that fascinated me as a kid. Must have been destined to restore old things :D .
I can remember where I put it, but I can look through the same box or on the bench for 10 mins and then give up :wh:
Only to look a little later and it was exactly where I thought it was, and had looked :D
I think I must being going blind...
iicap
Just a note on the painted spark plug. It may not apply today but in years past paints had lead in them. We were taught never to paint the porcelen of a plug as it was possible for the spark to travel to ground thru the paint to the nut of the plug and give a no fire or misfire at times. As an example our teacher took a plug and lead pencil, drew a line from the top terminal to the nut and it prevented the plug from firing.............Oh I was 14 then, now I'm 68, at least the memory is still ok.
sgtsampay
Looks great! Very nice restore!
Stigian
made a linkage for my son's westwood at the weekend from a handy piece of rod... unsure.gif
turns out it was the PTO control rod
Did you find a new PTO control rod Mark?
I've got a spare one your welcome to have.. Easy enough to put in the post.
I saw you were bidding on the trans I had on fleabay, for another project?
That's a first class job your doing on your C-101, a very nice paint finish..
I must remember Crown flame red paint when the time comes to paint my 6x6 project :thumbs:
