specialwheelhorse 174 #51 Posted December 18, 2012 Ace Hardware has all the goodies you need to pull this off !!!!!!!!!!!!!!!!!!! Jim in Texas Share this post Link to post Share on other sites
Tankman 3,515 #52 Posted December 18, 2012 Terry, what's the practical advantage of pressed-in studs over the Grade 8 bolt method? Not being critical, just curious? Duff There isn't any advantage unless you already have the wheel studs. They are definitely a 'fix' for stripped hub threads though. The "fix" is a great example when studs would be preferred. Right not, no stripped hubs, stickin' with 7/16-20 x 1-1/2" bolts with a small flat washer. Why take the chance of damaging a good hub? Just finished my 2nd 400 WH hubs. Nice, easy enough to change tires. Share this post Link to post Share on other sites
