catman81056
Eletric clutch removel
One of the tractors I got from the junk yard is a C-121/Electro 12
I need to know how to take the clutch off, can anyone fill me in?
Thanks in advance. :thumbs:
Tim, once you remove the retaining bolt it "should slide off" but it could take a little help to get it off <_
There's a sticker on the outside of it that says something about threading a 5/8-11 into the clutch bore but the rest of the sticker is gone :thumbs:
Tim the inside bore of the clutch is threaded.
Take the retaining bolt out & use a 5/8's 11 to thread back in...should push it right off the crank.
Double check to see if it rreally is a 5/8" 11 & do not force it if it gets stuborn.
Good luck :thumbs:
