ragster1
Ignition problem 1987 WH 211-5 w/ 11HP B&S
ragster1
My ignition switch does not turn the motor off and need advice on the proper wiring placement. To turn the motor off I pull the spark plug off. This occurred after I dismantled the tractor for painting and failed to take before and after pictures showing the wire connection locations. Any help is appreciated.
Don1977
Did you paint the dash, it may be that the switch is not grounded.
ragster1
Turns out it was a grounding issue. Tractor looks great and works great! I even had time to paint the 37" SD deck to match the tractor. :)
