TT
Fellow Redsquare "campers"
TT
Thanks, guys! :thumbs:
The "co-constructor" also says it's quite small! :thumbs:
TT
Chapter 3, Page 1......... :thumbs:
The black tractor was disassembled down to the frame/trans stage again. The lower steering shaft needed extended 3", so it was cut, sleeved, and welded. Two new holes were drilled in the frame for the lower steering support, and 3 holes were drilled for the new location of the engine. (I used an extra oil pan as a template)
The front axle mount on the frame also received new 3/4" holes about 1 inch above the stock location. The 551 front axle pivot bolt hole was also drilled out to 3/4" so a new-style bolster pin could be used.
As of right now, the floor to end of frame measurement is 10". As a comparison, my 1056 measures 15". :D
I was quite busy working, so I didn't get many pictures. :thumbs:
kj4kicks
Wow TT !! That is lookin' good !!
I love the dropped front axle look. I think it needs a polished aluminum "mini-keg" mounted in front of the hood yet. Whadda ya think?
Keep up the black magic.....
Kelly
Lookin good, now I need to get one going. Oh to many projects so little time and money.
TT
I think there's a "Barrel of Monkeys" container in Mom & Dad's attic. :thumbs:
A little simulated chrome paint & a couple hose clamps should make a pretty good replica, wouldn't ya say ????? :thumbs:
I have a little re-engineering to do up there first -- as soon as I get through all this tough mechanical work. :D
Rollerman
TT I just noticed the paint stand there in the back ground.
Do you tie that down when it's windy?
Rat Rods looking great...can't wait to see further progress.
