mavfreak
'78 '79 c161 twin eight speed
mavfreak
ok I don't have a model number a OP removed it.
Does anyone have a diagram
or...
A model number so I can look up
The tractor runs all switches were removed and the lights wiring were cut. Wiring is in a rats nest condition and I want to clean it up and get my lights working once again.
Thanks
tgranthamfd
I have a Wheel Horse Electrical Pdf file but I can't figure out how to attach it, it is a 54 page file. :D
bo dawg
Mine is a 79 C-161 that had the BS twin on it originally, my m# is 91-16BS01
That will get you a wire diagram :D
rmaynard
Check the file size. If it's larger than 56K it won't attach.
Bob
tgranthamfd
If you don't mind giving me your regular e-mail address, I will try to send you the file when I get home from work. You could just pm it to me through the sight if you don't want it out in the open.
tgranthamfd
Got to the pinned links at the top of wheel horse tractor, select the one that says something about on the 4th line down, on the 4th line enter C-161 Twin, and you can look at all the drawings.
Fiddlestix
Just in case you have hydro or 8 speed...
'79 C161 twin #'s:
91-16B801
1979
C Series Garden Tractor
C-161 Twin
8-Speed
Briggs
91-16B802
1979
C-161 Twin
8-Speed
Briggs
91-16BS01
1979
C-161 Twin
Automatic
Briggs
91-16BS02
1979
C-161 Twin
Automatic
Briggs
Once you get to the Toro site and have entered a number, and have navigated your way to the manuals available, download BOTH the B,C,D, Service Manual AND the Electrical Supplement. The general schematic and a good pictorial reference of the harness and doodads for your harness are contained in that Service Manual. The Electrical Supplement does not have a specific schematic for your machine as most of them that would apply are showing an engine and system with a battery coil ignition and not magneto... your B&S is magneto correct?
But do scan through the Electrical Supplement, there are good pics of what components look like. :D
mavfreak
thanks I just down loaded what I needed
I really appreciate the help :D
looks like everything is there just cut and unbundled so I'm guessing some new connectors and some electrical tape and wire ties
Thanks again :USA:
tgranthamfd
Good luck with it all. If you need any ideas, I just replaced all the lighting system on my C-145, it is posted in the work in progress section. Had some good replacement parts at good prices, replaced all with new wiring for around $50.
mavfreak
I do believe the headlights setup on the c 161 is unique to this year. Its the first fiberglass black hood. I think
C-Series14
You are correct. The lens is different than the normal C-Series. It is wider. It was expensive when I bought one several years ago AND proceeded to break it a year later. :D
Now, I think it is discontinued....
tgranthamfd
What's different about the lenses? :USA: Does it not have individual head lamps?
tgranthamfd
What's different about the lenses? :D Does it not have individual head lamps?
I found a picture, I see the difference now. :USA: Looks like a transition type thing.
C-Series14
I just looked it up and it shows a price! I thought they were discontinued...106829 is the Twin part number and 103771 is the other. About the same price. The Twin doesn't have the decal...
mavfreak
so they are still available then?
C-Series14
When I added it to my cart, it showed a price. I use sepw.com
I will eventually need a new one when I re-do my 1979 Twin so I might order one and see...
It was $28 plus change.
C-Series14
Type TO
Part ID: 106829
Description LENS-HEADLIGHT
Qty:
Unit Price 28.93
mavfreak
cool
