uni drive rebuild 5025
  • Please log in to reply
23 replies to this topic
#1 ONLINE   stevasaurus
stevasaurus
    RedSquare Expert
  • Supporter
  • 4,549 posts
  • Joined 29-October 08
  • 46 thanks
  • Military Member: Navy
  • LocationElgin, Illinois
Posted 30 March 2010 - 06:23 PM
My intent here is to show lots of pictures so if anyone is rebuilding one of these or some of the others...you can do it without fear and I am adding some very helpful information. I had a post that lead up to this that has some information in it also, and while it overlaps, I wanted to do the rebuild separate. This post is meant to be used with the manual...the pictures help explain better then the pictures in the manual.
the lead up post.
http://www.wheelhors...showtopic=14943
Now I want to share what I learned as I rebuild this...I realize that some have done this, but this was my first time (transmission virgin) and I know I am not the last one to do this. If I can help or make this easier, then I have given back a little from all the help I have received from this site. :omg:
This is a shot showing gear placement in the left side of the case. Notice the bevel of the reverse gear (front right). The left side is the shallow side of the transmission halves.
Posted Image
These are the parts of the differential..the 2 casings on the outside, the 2 axles, the differential bull gear, the 4 posts and the pinions that go on these, and the bolts and nuts that hold it all together.
Posted Image
I can't get enough looks at the gears before I tear it apart...next 2 pictures are for future reference.
Posted Image
Posted Image
I found a good assortment of 3/8 and 1/2 sockets that made fair to good arbors for pounding out and tapping in most of the bearings and seals.
Posted Image
These are the bearings and seals you need to do the R&R. You can get all the stuff from Toro or the site that Jason gave in the related post. One note...the Toro#1303 seal is discontinued. This is called a cup seal, because it has a cup shape. I replaced it with a kind of match (SKF #7410) same dimensions but more like a regular oil seal...it will work. This place used to be Berry Bearings in Elgin...now it is "Motion Industries"...the web site MotionMRO.com...they can match up any bearing or seal. Excellent info. and prices were very good.
Posted Image
Shot of the bearings and seals removed, cleaned and sanded. Used Valspar Restoration series...I like the red match with my 702 and I like the hardness of the paint.
Posted Image
Showing bearings and seals installed...notice (arbors on right).
Posted Image
Posted Image
Putting differential back together...show axle in place with bolts in place.
Posted Image
Added pinion posts and in 2nd picture...added pinions (alternating one up and one down).
Posted Image
Posted Image
Added Bull Gear
Posted Image
Added other axle and case and bolted together. At this point, make sure you can rotate the axles...they should rotate in opposite directions.
Posted Image
Placing input shaft and gear (one piece) and the reverse idler shaft.
Posted Image
Installed the 2nd & high shift rail and fork. (one on the left). Also installed both ball bearings, spring and stop pin, and low & reverse shift rail. The 2 sliding gears were then placed...the grooves face each other and the smaller gear goes on the bottom.
I had a pencil magnet that I used to hold the 2nd ball bearing, while I took an Allen wrench through the hole to hold the bearing out of the way while I placed the low and reverse shift rail. the picture also shows the reverse idler and brake shaft in place.
Posted Image
Posted Image
Another view showing forks and gears.
Posted Image
Showing reverse idler (bevel up...I hope) in front. Splined shaft installed through the shift fork sliding gears. The cluster gear is then installed( 2 wood-ruff keys here...one on each end). Also, the differential and axles are placed (note the nuts are facing up).
Posted Image
different angle
Posted Image
yet one more angle
Posted Image
Put together..old 5 gal wood create works great as a work bench (all shafts fit through and keep work level). Used a hard rubber hammer to tap halves together.
No leaks when I filled with 90wt gear oil...approx 1 1/2 qts. Checked shifting and started to put the 702 back together today. A final picture or a video tomorrow (hope).
Posted Image
I want to thank Rickv1957 Fan, MikeRJ, Buckrancher,Suburban550,IndyWH Smokin'Joe, the Helmett and Charlie for all their help and advice...a huge thank you guys. :D :D :D
Thanked by 2 Members:
bob393 , woodbird007
#2 OFFLINE   rickv1957
rickv1957
    RedSquare Expert
  • Members
  • PipPipPipPipPipPipPip
  • 5,167 posts
  • Joined 14-December 08
  • 2 thanks
  • LocationLawson Mo
  • favoritemodel:
    NOS 1974 D180
Posted 30 March 2010 - 06:35 PM
Steve,Tranny is looking good,glad to have helped! :omg: :D Rick
Thanked by 1 Member:
woodbird007
#3 OFFLINE   clintonnut
clintonnut
    Senior Advanced Member
  • Members
  • PipPipPipPipPip
  • 1,487 posts
  • Joined 15-August 08
  • 0 thanks
  • Locationsoutheast pennsylvania
Posted 30 March 2010 - 06:36 PM
Looks great. How much did you pay for all of the bearings together? You bought the 1533 bearings from toro? They are around $70 now.
What is Jason's site? I am interested because my bearing distributers prices have gone through the roof. I'm getting tired paying $12 for a bearing I can slip over my little finger!
Charlie
#4 OFFLINE   Lane Ranger
Lane Ranger
    Supporter
  • Supporter
  • 1,234 posts
  • Joined 17-May 08
  • 12 thanks
  • LocationGreencastle, Indiana 46135
  • favoritemodel:
    RJ-58 and B-80!
Posted 30 March 2010 - 06:52 PM
Steve: This is great that you took so much time and care to share with others on Red Square for the rebuild.
A fantastic job!
:omg:
#5 ONLINE   stevasaurus
stevasaurus
    RedSquare Expert
  • Topic Starter
  • Supporter
  • 4,549 posts
  • 46 thanks
Posted 30 March 2010 - 07:42 PM
Charlie and everyone else...this is Jason's site...
http://www.rcpw.com/...3&search=Search
The old berry bearings in Elgin is now Motion Industries
e-mail....MotionMRO.com They can match any bearing(I am told) or seal if you give them the O.D. I.D. and height of the bearing or seal. The guy behind the counter is a guy I have known since the late 60's and the service station days. He is still excellent and very helpful. If you end up calling him, you can mention my name, will not lower the price though. He is the kind of guy that...if you are an a-hole...but if you are serious, he will bend over backwards. When I told him that only Toro made the #1533 bearing and had to get it from them...he looked at me and rolled his eyes. I did not have the I.D. O.D. and height at the time to check it out. If someone has those measurements, I will go back and see if he can match it up. Well worth the time. :omg:
#6 ONLINE   stevasaurus
stevasaurus
    RedSquare Expert
  • Topic Starter
  • Supporter
  • 4,549 posts
  • 46 thanks
Posted 30 March 2010 - 07:48 PM
Sorry Charlie...(remember that from a tuna commercial), I don't know how you can do the trans rebuild for $150 with core deposit. I spent a little more then that.
House prices may have come down, wages are lower, but machined parts are not cheap. :omg:
#7 OFFLINE   bmuone
bmuone
    Senior Member
  • Members
  • PipPipPipPip
  • 315 posts
  • Joined 08-September 08
  • 1 thanks
  • LocationNE Texas
  • favoritemodel:
    matters not
Posted 30 March 2010 - 08:13 PM
A+ on that post Steve. Tk U for that effort. :omg:
#8 OFFLINE   Indy w h
Indy w h
    Senior Member
  • Members
  • PipPipPipPip
  • 993 posts
  • Joined 23-September 09
  • 0 thanks
  • LocationNew Richmond IN. 47967
  • favoritemodel:
    701
Posted 30 March 2010 - 11:31 PM
Glad to help ya out Steve!!! Just be careful putting it back in
the 702 !!! Hate to see you hurt yourself again :omg:
Indy
#9 OFFLINE   tgranthamfd
tgranthamfd
  • Members
  • PipPipPipPipPip
  • 1,055 posts
  • Joined 19-April 09
  • 0 thanks
  • LocationMarlow, OK.
  • favoritemodel:
    05 315-8 Classic GT
Posted 31 March 2010 - 01:35 AM
Nice tutorial. Looking forward to the video of her back on her feet. Good job. :omg:
#10 ONLINE   JimD
JimD
    12-0 An Urban Legend...
  • Supporter
  • 3,099 posts
  • Joined 29-August 08
  • 22 thanks
  • LocationGarrettsville,Ohio
Posted 31 March 2010 - 02:12 AM
We all knew ya could do it Steve. Great job on the tranny and the thread! :omg:
#11 OFFLINE   Save Old Iron
Save Old Iron
    Red Square Expert Emeritus
  • Members
  • 2,164 posts
  • Joined 16-July 09
  • 48 thanks
  • LocationUpstate NY
Posted 31 March 2010 - 04:41 AM
Way to go Steve,
just a quick ? about the orange coloration. Is this just surface rust on the gears, shafts, etc, or is it residue from old water / oil contanimation ?
I'm assuming if you could have just wiped it off, it would have been.
Great Job :omg:
#12 OFFLINE   Suburban 550
Suburban 550
  • Members
  • PipPipPipPipPip
  • 1,484 posts
  • Joined 09-January 08
  • 0 thanks
  • LocationShenandoah, Pennsylvania 17976
Posted 31 March 2010 - 05:50 AM
Great job, Steve. :D I'm really proud of you, not only for rebuilding the tranny, but doing it without any injuries to yourself. :D Good luck reinstalling it and great pics. :omg:
#13 OFFLINE   dclarke
dclarke
    Supporter
  • Supporter
  • 1,286 posts
  • Joined 19-March 09
  • 12 thanks
  • Locationpawnee il.
  • favoritemodel:
    round hoods
Posted 31 March 2010 - 06:18 AM
great job Steve! this will benefit a lot of people, including me. thank you. :omg:
#14 OFFLINE   Coadster32
Coadster32
    RedSquare Pro
  • Supporter
  • 2,673 posts
  • Joined 03-December 08
  • 3 thanks
  • LocationMilford,CT
Posted 31 March 2010 - 09:08 AM
Good job Steve. :omg: Thanks for sharing.
#15 OFFLINE   trapperjoe
trapperjoe
    Newbie
  • Members
  • Pip
  • 7 posts
  • Joined 25-March 10
  • 0 thanks
Posted 31 March 2010 - 10:14 PM
Great informational post and great pics too!
Now... who wants to do a tutorial with my... their GT-14 hydraustat ?
Joe
#16 ONLINE   stevasaurus
stevasaurus
    RedSquare Expert
  • Topic Starter
  • Supporter
  • 4,549 posts
  • 46 thanks
Posted 01 April 2010 - 04:59 PM
The transmission is working fantastic...after witnessing the water damage in a trans...I would tear down every trans suspected of having water or sledge in it. Way to easy and the cost of a $5.00 gasket and piece of mind, versus the cost of bearings...up to $300.00 and going up. I have 3 more horses that were stored with this one...guess what I will be doing in the next few months?
:D
Anyway...a couple of shots of the horse recipient of the rebuild...
Posted Image
Posted Image
After doing all that cleaning and painting.....you can't see it...but I know it is there and feel good about it. :D
Here is a very short video...because how many times can you go back and forth :D
but notice how easy this starts after sitting since the end of December. Without a doubt...the easiest starting engine I have ever seen. :D :omg:
Posted Image
I've been riding this around the block for the last couple of days...working it in so to speak...needs a cup holder. :D
#17 OFFLINE   wheelhorse551
wheelhorse551
    Member
  • Members
  • PipPip
  • 13 posts
  • Joined 17-March 10
  • 0 thanks
  • LocationConnecticut
Posted 03 April 2010 - 08:23 AM
I had one of the older 3-part transaxles. It had water damage and I bought a new one on eBay for $51.00 and $46.00 to ship. I had to switch the side cover because the brake band opened when the clutch/brake pedal was pressed. :omg: I tried it yesterday and it works great. :D
#18 OFFLINE   SAM58
SAM58
    Senior Member
  • Members
  • PipPipPipPip
  • 664 posts
  • Joined 16-June 10
  • 3 thanks
  • LocationPaintsville, KY 41240
Posted 19 June 2010 - 02:50 PM
It looks like I am going to have to do the same thing, and do a complete rebuild on my 6 speed trans in my Raider 12. it has ran great for 38 years and i think i have an axel clip falling apart. as long as i have it apart i am going to relace all the bearing & seals.
Does anyone have the crossover numbers to listed parts with a good suppier?
The repair manual shows my trans. is a 5073 1972 model
never been inside a trans before, looks like it can be done.
#19 OFFLINE   dgjks6
dgjks6
    Supporter
  • Supporter
  • 881 posts
  • Joined 28-May 08
  • 0 thanks
  • LocationAkron, Ohio
Posted 19 June 2010 - 07:58 PM
they are not hard to take apart. Outting it back together is another story. Just remember to take out the shifter before lifting off the top half :thumbs:
#20 ONLINE   rmaynard
rmaynard
    B-100 BOB
  • Supporter
  • 5,286 posts
  • Joined 25-November 09
  • 54 thanks
  • Military Member: Coast_Guard
  • LocationNew Windsor, Maryland
Posted 19 June 2010 - 09:12 PM
Sam,
Click on this link and it will take you to the Toro site. Enter the model number of your tractor and you will find a free download of the transmission manual.
Toro Manuals
Bob
:thumbs:
#21 OFFLINE   Duff
Duff
    Supporter
  • Supporter
  • 3,471 posts
  • Joined 06-November 07
  • 13 thanks
  • LocationWest Lebanon, NH
  • favoritemodel:
    312-8
Posted 21 June 2010 - 12:28 PM
[quote name="SAM58"]It looks like I am going to have to do the same thing, and do a complete rebuild on my 6 speed trans in my Raider 12. it has ran great for 38 years and i think i have an axel clip falling apart. as long as i have it apart i am going to relace all the bearing & seals.
#22 ONLINE   stevasaurus
stevasaurus
    RedSquare Expert
  • Topic Starter
  • Supporter
  • 4,549 posts
  • 46 thanks
Posted 21 September 2010 - 09:40 AM
bump
#23 OFFLINE   bob393
bob393
    Member
  • Supporter
  • 12 posts
  • Joined 08-May 13
  • 0 thanks
  • LocationGoshen, NY
  • favoritemodel:
    D-250
Posted 11 May 2013 - 08:19 AM
Steve, This is a fantastic post, and thread. It makes the rebuild look almost possible.
#24 OFFLINE   tracer
tracer
    Member
  • Members
  • PipPip
  • 13 posts
  • Joined 01-March 13
  • 0 thanks
  • Locationkentucky
  • favoritemodel:
    653
Posted 13 May 2013 - 05:47 AM
Thanks Steve for the overhaul information and pictures,,,,I might need them. Pictures sure help a fella out,,,especially me.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
