Kelly
Clean it up and use the rings you have.
MalMac
I second that, just clean it up check for any marring or scuffing that may have occurred but very unlikely with only 8 or so hours on it. If it's without any imperfections put it together.
HorseFixer
Just oil um up real good, and slip the sherbert to her herbert. :thumbs:
~Duke
dclarke
Thanks guys, looks like I'm good to go.
Suburban 550
Denny, I know where I'm sendin' my 701 to get finished. Great job, my friend.
dclarke
I picked up this cultivator to put on my 701, there isn't much of it that's not bent. I got the front section straightened out and rewelded this morning, I still have a shank or two and the rear section to straighten. I always thought these looked good mounted on a tractor, I'll have this painted when the tractor gets painted.
Jake Kuhn
That will look fantastic on there dennny!
AMC RULES
Agreed, the :wh: cultivators do look cool. :handgestures-thumbsup:
dclarke
I didn't get the lift arm with this cultivator, if anybody has one and can get the measurements so I can make one I'd sure appreciate it. I think this is a model AC-675 cultivator, the lift arm number is 5581. Thanks.
Denny
MalMac
Denny! you stoled my idea. Thats what I have waiting to put on my 701. Thought it would look good on there. Was going to use the side mount sickles but someone bought them before I got them cleaned up. Like you I have got to fab a lift bar.
clemedc
Im wanting one of those cultivators too and would like to know what the lift bar looks like, BTW Denny I belive we met when you purchased the cultivator.
Clem
dclarke
Clem
Clem, Nice to meet you... I've been wanting a cultivator for a while, I was lucky to be able to pick this one up.
welderman85
very nice work the 701 looks great
jusjeepn
Denny, you WERE lucky to pick those up! I was there the day before and he wouldn't budge off of them.
HorseFixer
Looking Good Denny! :handgestures-thumbupright: I have a lift arm Ill Get you Measurements and Could Prolly Mail em to you. Gemme a Couple Days.
~Duke
dclarke
~Duke
Thanks Duke!!
dclarke
The body shop called today and told me to bring my tractor in tomorrow to be painted, been waiting since September for that phone call. Hope it's worth the wait.
  • Like 4
dclarke
I've got a few pieces back from the paint shop over the last few days, I should get the frame back tomorrow. I know you guys like pics so here ya go.
  • Like 4
dclarke
I posted two pics of the same fender, this is the pic I wanted to load.
clemedc
looking good Denny
Jake Kuhn
looks awesome!
Mr. 856
not a spray bomb job there. Looks amazing. Shes going to be a beauty!
clintonnut
What's the paint? I think I'm using BC/CC on my RJ35. Overkill, I know.
dclarke
Charlie, it's PPG Omni, bc/cc, code 70019 over a dark epoxy primer.
Ken B
Looks awesome Denny! I must say, that is a very neat and well organized shop you have there! Love the safe.
Edited by Ken B
  • Similar Content
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
    • NJ Tom
      By NJ Tom
      Just finished my winter project. I also restored the plow blade, now I'm going to look for some attachments.
