Prater 75 #1 Posted December 20, 2009 Anyone use an Accel single fire super coil for Harley Davidson on their twin Kohler? I am adding one to my D180 in place of the two 12Volt coils that were wired in. Just wondering if there is any tips or tricks I should know to protect the ignition system. Thanks Share this post Link to post Share on other sites
rickv1957 70 #2 Posted December 20, 2009 I did buy a 180 a while back with a Harley coil,it ran great but have changed it back to the original.Rick Share this post Link to post Share on other sites
Don1977 604 #3 Posted December 21, 2009 I did buy a 180 a while back with a Harley coil,it ran great but have changed it back to the original.Rick Rick how was the coil mounted on the engine? Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #4 Posted December 21, 2009 Here's a link to the last discussion: http://www.wheelhorseforum.com/index.php?showtopic=13230 The "old-school" H-D Prestolite coil and the ones used on the big K series twins might even be one in the same. They certainly look very similar. Share this post Link to post Share on other sites
Prater 75 #5 Posted December 21, 2009 TT, I have read that thread already. I was specifically wondering if anyone had used the coil that I was planning to use. Its a single fire that I will have to cross the two negative posts on. I was able to get it for about half the cost of a Dual Fire that only has one positive and one negative terminal. Mine has one positive and two negative terminals and runs 3 ohms. Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #6 Posted December 21, 2009 Theoretically ( ) you should be able to run a jumper wire between the two negative posts and use the single points lead to fire both coil "halves" simultaneously. Share this post Link to post Share on other sites
Prater 75 #7 Posted December 21, 2009 Here is how I have it wired in so far. I made a bracket out of some scrap aluminum. No more wire ties holding on the coils... I need to get some new plugs and plug wires. I will probably just make my own wires from a kit if I can find it in the attick. here was the before pic Share this post Link to post Share on other sites
rickv1957 70 #8 Posted December 21, 2009 Steven your mounting of coil looks great!!!,Rick Share this post Link to post Share on other sites
