1961551 2 #1 Posted September 21, 2009 HI, I BOUGHT A 551 FOR MY SON, WHICH HAS BEEN SITTING FOR A LONG TIME. THE TRANS IS LOCKED UP. BEEN SITTING ON CONCRETE FOR A LONG TIME. TRIED FILLING IT WITH KEROSENE AND LETTING IT SIT FOR A WEEK.SHIFT FORK SHAFTS WERE STUCK. WELL, ITS APART NOW. ALL GEARS AND SHAFTS ARE VERY GOOD. TORRINGTON BEARINGS ARE INTACT BUT SOME ARE FROZE. SUBMERGED CASES IN MURATIC ACID OVERNIGHT. CASES ARE CLEAN NOW. BUT I AM GOING TO HAVE TO HAVE SEVERAL BEARINGS A GASKET AND AXLE SEALS. WERE DO I GET PARTS? CANT FIND THEM ON THE INTERNET. THANK YOU JIMMY IN N.C. Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted September 21, 2009 Gaskets and seals are available through your Toro dealer, the gasket is $3 or $4. Seals are available through NAPA as well, but they normally have to order them. All the needle rollers are available from Motion Industries, the last set I got was about $80. The 2 roller bearings on the diff are only available from Toro, and are about $60 each. Save them if you can! Share this post Link to post Share on other sites
bowtieguy 334 #3 Posted September 21, 2009 I buy most of my bearnings from IBT in Kansas....try www.ibtinc.com ....ususally about half the price of a dealer.... Share this post Link to post Share on other sites
tgranthamfd 28 #4 Posted September 21, 2009 Which bearing numbers do you need? Maybe coadster will see this, he just rebuilt his 551 transmission. He has a post in the work in progress section, as well. Share this post Link to post Share on other sites
tgranthamfd 28 #5 Posted September 21, 2009 If I did this right, here is a link. http://www.wheelhorseforum.com/index.php?showtopic=8596 Share this post Link to post Share on other sites
Duff 206 #6 Posted September 21, 2009 Jimmy, also try this thread: http://www.wheelhorseforum.com/index.php?showtopic=11330 Toward the bottom there's a post with a PDF bearing cross-reference chart that's very useful. I used it to order my bearings from Motion Industriers and it was right on the money! Duff :scratchead: Share this post Link to post Share on other sites
HorseFixer 2,012 #7 Posted September 21, 2009 Jimmy, also try this thread: http://www.wheelhorseforum.com/index.php?showtopic=11330 Toward the bottom there's a post with a PDF bearing cross-reference chart that's very useful. I used it to order my bearings from Motion Industriers and it was right on the money! Duff Thanks for the link Duff yep Motion Industries is where I get all my stuff too! Never had anything they couldnt match yet! :scratchead: Share this post Link to post Share on other sites
Coadster32 793 #8 Posted September 22, 2009 Kaman is where I get my bearings from. McMaster Carr has some great double sided seals for the axles as well. I haven't used Motion, but I may try them in the future. Share this post Link to post Share on other sites
1961551 2 #9 Posted September 23, 2009 thanks to all that replied. i have came to the conclusion that i am going to have to rob the one out of the 700 for now. after cleaning, i need a cluster shaft and all bearings. cash is tight. wife is pregnant. i guess i'll use what resources i have for now. thank you, everyone. jimmy Share this post Link to post Share on other sites
