Crow Horse
Creature Comfort Mods ??.........
Crow Horse
I'm curious as to what creature comfort mods folks have done to their horse(s). I'm noodling making a rear rack that will slide onto the outboard parts of the rear axle and pin to the hitch as a support. From there it will angle up to support the rack (relatively small). I'm looking to fab up an easy to install/remove rack system that will also allow the hitch to be used. I'm just noodling this now.
My goal is to make a rack that will contain items like tools, chainsaw, etc. without having to hook up a wagon......
If this idea precipitates, maybe a drink holder would be in order......
WHC-125
Crow Horse, I have a Dynamark that looks like this if this gives you any ideas.
sawhorse
Wilbur! That's a sheep in horse's clothing! :thumbs2:
One simple "creature comfort" I have done recently is to make
an attachment point on the back of the seat where one of those
blinking LED lights can be attached. I got one of those lights
from a bicycle store that flashes red for safety to the rear of the
bicycle and mounted it on the horse for safe snow plowing this winter.
Now I am sure I will be visible....
W9JAB
Make it E-Z to change oil
See the leaf sweeper after dark
Have more fun driving
Duff
Crow, I'd take a run to a local ATV dealership and have a look at some of the racks they put on those machines. Might give you some fodder for thought? :thumbs:
Duff :thumbs2:
Crow Horse
Lots of good ideas! Keep em' coming!
One thing I did was to add a zirc fitting to the clutch pedal. The same will be done to the brake pedal.........
sawhorse
I fabricated a sleeve hitch for a B-115 automatic vertical shaft tractor. The lift rod
is attached to the deck lift arm.
Below is the deck lift arm on the B-115. notice the extra notches I hogged out for
extra lift...
So that I can pull this old modified plow through the ground. In previously worked soil
only.
This machine drags a brinly cultivator very nicely. The automatic transmission
makes for easy cultivation of row crops of vegetables such as corn.
This setup will pull this homemade potato plow....
Which makes nice rows for onions, potatoes, and for transplanting of various cell
packs of vegetables.
