baerpath 517 #1 Posted February 9, 2008 Anyone know off hand if a deck from a 308-8 would fit a Commando 800. The deck on this one has a 4 inch hole in it and I have the 308 deck sooo....... :thumbs: Share this post Link to post Share on other sites
nylyon-(Admin) 7,114 #2 Posted February 9, 2008 Yep, they should both be the attach-a-matic models should fit right on. Share this post Link to post Share on other sites
nylyon-(Admin) 7,114 #3 Posted February 9, 2008 I just remembered something that Mike mentioned. The 308-8 could have a 37" SD mower (I think) which required smaller front tires. If the deck on the 308 is this one it might hit the tires, if not then there is no problem. Share this post Link to post Share on other sites
baerpath 517 #4 Posted February 9, 2008 I thought so, but I see the rear gauge wheel bar isn't the same but thats probably because of the ten inch rear rims. Share this post Link to post Share on other sites
baerpath 517 #5 Posted February 10, 2008 I just remembered something that Mike mentioned. The 308-8 could have a 37" SD mower (I think) which required smaller front tires. If the deck on the 308 is this one it might hit the tires, if not then there is no problem. I have both rear and side discharge for 37 inch deck Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #6 Posted February 10, 2008 The 37" deck is the offset 2 blade model, Duane. (That's the one that takes the 6 sided belt and the double V pulley tensioner.) The small 3 blade decks are 36" and will fit all of the Attach-Matic tractors. (provided they are made for the "garden tractor" models) Share this post Link to post Share on other sites
baerpath 517 #7 Posted February 10, 2008 Both are three blade decks Could be 36's one is rear discharge the other side discharge. So I should be able to use either :thumbs: Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #8 Posted February 10, 2008 If you happen to decide to "scrap" the original deck off the Commando, I'd be interested in buying a few of the hanger brackets from you. I have a deck shell off a vertical shaft tractor I want to combine with the original deck from my B-80 to make one good one. Whoever did the patching on the B-80 deck thought it was alright to weld around all of the brackets and now they won't come off without MAJOR work. Here are the pieces I need (highlighted in yellow) if you want to part with them. Share this post Link to post Share on other sites
baerpath 517 #9 Posted February 10, 2008 Scrap whats that ?? I grew up on a farm those are parts not needed right now Might need them next year or later But yes when I get the deck off and change it Won't be for a while though. Duane Share this post Link to post Share on other sites
