wheelhorse101
good day went baddd
wheelhorse101
well today was a good day until i went to go load my c-81 loader onto the trailer and clunk there gos the transmission on the darn thing no gears work whats so ever this sucks and i had work to do with it tommarow :thumbs2:
nylyon
Maybe it's the key on an axle?
WHC-125
Dan, what happened :thumbs2: ? Is it the hub again or inside?
d180man
Hi hope it is not to bad!! we have had that happen too ! :thumbs2: did it brake the trans? or just stop moving? :thumbs:
wheelhorse101
just stoped moving and in every gear it dosent do anything axles arnt spinning either so im not sure what i have to do now :thumbs2:
WHC-125
Did you check the belt? And try low range.
wheelhorse101
checked it all when its running i can shift threw all the gears without putting the clutch in not good
Jim_M
Broken key between the driven pulley and transmission input shaft?
wheelhorse101
i fixed it thank god it was only the key for the pully on the tranny :thumbs2:
stevebo
Dan,
Glad to hear it worked out. Rember you don't have to work that thing too hard...
