Fire_rescue_18
310-8
Fire_rescue_18
My 310-8 has started surging periodically. I replaced the fuel line thinking that maybe the fuel line was sucking shut. replaced fuel filter and put a nw H10C Champion plug in it. It still surges periodically. I sprayed ether around the carb with it running and it rev's when sprayed around the throttle shaft. It is a little bit wobbly. I Guess my question is how wobbly is too wobbly for a throttle shaft?? and should I just replace the carb or bush the housing??
Fire_rescue_18
Could the surging be another problem???
Duvall
Any bit of wobbling from the throttle shaft can cause an air leak and could make the engine surge.
That would be the first place I would start.
Fire_rescue_18
I fixed the problem with an inine electric fuel pump. I put a see through filter inlin and could see thatit was running out offuelmaking it bog down. I ordered some throttle shaft bushings and will do that next.
Fire_rescue_18
I guess I need to learn how to type and or proof-read!! :thumbs2:
Duvall
Be careful with an electric fuel pump.
The needle and seat in the carb are not good for much more than 5 or 6 psi
If you start getting a flooding problem you will know why.
Fire_rescue_18
It is a 4-6 psi pump for small engines but thanks for the advice just incase I had not known or maybe someone else would have used a higher volume pump. What I don't like is that it is a magneto engine so I had to put it on a toggle switch rather than the coil. I was unable to find a wire that was hot when only the key was on.
