tarcoleo 119 #1 Posted July 20, 2009 On my C-111, I have been using a 36" deck equipped with a Tech-O-Matic mount. Bought a 48" WH deck similarly equipped but it does not quite fit the C-111. The manual deck lift does not quite engage the available hole in the deck harness. Comparing the two decks, there is an extra oblong hole in the smaller deck harness that is not drilled in the larger one. Of course I can drill, or switch the two harnesses, but is there usually such variation? swamp yankee :thumbs2: Share this post Link to post Share on other sites
tgranthamfd 28 #2 Posted July 21, 2009 Not real sure. My brother has a 75 C-160, and he ordered one for my 05 Classic GT 315-8, and it fit his like it was made for it. But both of ours are 42" side discharge decks. The only differences may be rear vs. side discharge or cutting widths. Share this post Link to post Share on other sites
tarcoleo 119 #3 Posted July 21, 2009 I guess my question boils down to- how many holes are there supposed to be in the part of the deck where the lift lever engages the deck? The part in question runs forward and back, just a little right of center of the deck. In order to properly fit the C-111, there needs to be a hole, or slot, in that component that permits the the lift lever engaging boss to line up with the hinged attaching bar, the one with the "y" element. Without a second slot, there is too much distance for the attaching bar to be engaged. I'm wearing everybody out with this issue, not a big one. I'll just drill the darn hole or switch the two harnesses and be done with it. Its just that I thought all Tech-O-Matics were identical. They almost are. swamp yankee :thumbs2: Share this post Link to post Share on other sites
mcwh1950 2 #4 Posted July 21, 2009 swamp yankee - due you have a model number for the deck or a picture Share this post Link to post Share on other sites
tarcoleo 119 #5 Posted July 21, 2009 Smitty, Model no. not visible on my 48" deck. However, it is identical to the deck pictured and sold recently on ebay, item no. 230357766650. swamp yankee Share this post Link to post Share on other sites
