tarcoleo 119 #1 Posted July 13, 2009 Bought a 48 in. SD deck in general good order. Having a helluva time trying to remove the blades for sharpening. The 1-1/16" nuts will not budge even with wd40. I assume the threading is right handed. Have one wrench on the inside nut, one on the outside without success. What am I doing wrong? Share this post Link to post Share on other sites
Wilsonrl48747 0 #2 Posted July 13, 2009 The threads on all my mower decks are righty tighty, lefty loosie so that might help you out a bit. Sounds like things might be a little rusted. An old trick my father in law taught me was to take an old hairspray bottle and fill it with brake fluid and spray it on those stubborn parts. Its a lot cheaper than liquid wrench and works pretty good. A nice long cheater bar on your wrench might help too. Good luck Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #3 Posted July 13, 2009 I take it that you don't have an impact wrench or access to one, Tom? How about a torch? The nuts are RH thread and can be a real bastard if they haven't been off in a while. Share this post Link to post Share on other sites
C-Series14 15 #4 Posted July 14, 2009 Mine are 1-1/8". Put the wrench on the nut below the blade and have it up against the deck. Breaker bar and socket on the nut, pull hard. Alot of good ideas from the others, maybe PB Blaster also.... Share this post Link to post Share on other sites
tarcoleo 119 #5 Posted July 14, 2009 Thanks all. The nut is a small 1-1/8 or a large 1-1/16. I have a crescent wrench on the back nut and really good 1/2 sockets on the front nut. Crescent is jammed with a wood block and a really long handle on the socket. Way too much rust still. Liquid wrench, does it work? Like the idea of an impact wrench so I'll see if there's an auto shop hereabouts that can help me out. This is not a very good way to do things. The Gilson deck I adapted has a much better design and allows easy removal of blades, but, oh well. We'll get her. Thanks again guys. :thumbs2: Share this post Link to post Share on other sites
TT-(Moderator) 1,127 #6 Posted July 14, 2009 PB Blaster is the best aerosol penetrating oil I have found for the money. WD-40 does provide some lubrication and very good moisture protection/dispacement but is not a great penetrant. All I can add is "bear with it" and once you get the nuts removed, clean the threads on the spindles and apply anti-seize before assembly. You shouldn't have any future problems removing the blades. :thumbs2: Share this post Link to post Share on other sites
tarcoleo 119 #7 Posted July 14, 2009 Rob, TT, C-Guru- Happy tails! This is a pleased puppy. Took the deck to my favorite body shop (I've given him too much business) and with his trusty impact wrench, the problem was solved. I will be sure to put those sharpened blades back with anti-seize lube. Thanks for that. Don't know if you may need first-rate roller-bearing wheels and rollers, perhaps you guys into faithful restorations would not consider anything but original parts, but so far I just want to make the equipment work as well as it can. Toward that end I use wheels and rollers purchased from M&M Supply, listed on Ebay. Prices are great. Thanks and see you out on the lawn- Tom (swamp yankee) :thumbs2: Share this post Link to post Share on other sites
C-Series14 15 #8 Posted July 14, 2009 Take the deck off several times a year for many years and it becomes second nature. I have removed many decks on many tractors and the WH is the easiest in my book. Deck off, slid out, slid back in and back on in under 60 seconds!!! Neighbor lost a bet on that one! Glad you got it taken care of.... :thumbs2: Share this post Link to post Share on other sites
tarcoleo 119 #9 Posted July 15, 2009 C-Guru- I never was able to do the deck thing in 60 seconds, but I certainly do appreciate the WH design for deck attachments. The Gilson deck I mentioned is equipped with a WH harness taken from a junked 36" WH deck. The 48" deck project now comes down to designing an alternate means of attachment of the belt covers, so corroded were the original fasteners that they had to be cold-chiselled off to get at the belts and idler. Were I in a position to weld, things would be easy. <_< Share this post Link to post Share on other sites
