BPjunk
702 Tow Truck Tractor
Necesity is the mother of invention and here is living proof. With too many Wheel Horses in my yard it became apparent that I need to get them moved around easly when they were not running so a "A" type framed towing set up was made out of 1 inch square tubing. Then a boat winch was bolted to the frame with the cable hooked to a peice of bar stock placed in the slot hitch. The bar stock has "underlift" type hooks with a pivot so manuvering with a tractor hooked on the back could be done. This set works real well and will pull any Wheel Horse from a RJ-35 to a C series with no problem. The 702 was pulled out of the woods then tuned up and with the carburetor rebuilt and running ever since.
Bill in Richmond, Va.
Here is a veiw of the back end.
Attached Image (Click thumbnail to expand)
Another action shot.
Traction is unbelievable with a tractor on the back as it has towed a Wheel Horse through mud 6 inches deep and the old Kohler 161 7hp has more then enough power to get the job done!
