Operator manual #A-5251
6 pages 730.79KB
Includes PSB #083
Fits 875, 1075, 876, 1076 and 1276
Driven by hydro transmission pulley
Drive belt 1586 replaced by 9714 (HA x 76" or 1/2" x 76")
The attachment interchange states the 8-5211 speed hitch and 8-3112 pto are required but that does not sound correct.
Tiller 1966 36in model RT-366
Tiller DNA in the order they were produced
1966 tiller model RT-366
[Driven by hydro transmission pulley. Drive belt 1586 replaced by 9714 (HA x 76" or 1/2" x 76")]
1967 tiller model RT-367
Uses tiller hitch 7340
Rear axle hitch mounts behind rear axle
7353 idler arm mounts to rear of tractor frame
[Front drive belt 1586 replaced by 9714 (HA x 76" or 1/2" x 76") Rear drive belt 7358 (4L x 65.95" or 1/2" x 65.95")]
1968-1973 tiller model 7-1211
7697 idler arm mounts to rear of tractor frame
[Front drive belt for short frame models 867, 875, 876, 87 and 1075 #1576 replaced by 9691 (HA x 70" or 1/2" x 70")
Front drive belt for long frame models #1586 replaced by 9714 (HA x 76" or 1/2" x 76")
Rear drive belt for all #7358 (4L x 65.95" or 1/2" x 65.95")]
1973-1974 tiller model 7-1251
Uses tiller hitch 103629
Rear axle hitch mounts under rear axle
103632 idler arm pivots in hitch
No rear shield
[Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1975 tiller model 7-1252
Uses tiller hitch 104757
104660 idler arm bolted to hitch - following models welded
104437 rear shield mounted on 104438 rear piano hinge
1976 tiller model 67-36TL01
Uses tiller hitch 105543
1977 tiller model 77-36TL01
1977 tiller model 77-36TL02
106092 rear shield mounted by three straps
1978 tiller model 87-36TL01
No belt guard on front idler assembly
1979 tiller model 97-36TL01
1980-1982 tiller model 07-36TL01
Belt guard on front idler assembly retained by pulley shaft nut
1983-1985 tiller model 07-36TL02
First belt guard on front idler assembly to be retained by bolts to a welded-on bracket
1986-1989 tiller model 07-36TL03
1990-1991 tiller model 07-36TL04
[Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1992 tiller model 07-36TL05
1993-2001 2003-2007 tiller model 79370
