Switch Ignition Battery Keyed 88-9830 replaced by 104-2541 List.jpg 1.0.0
4 Screenshots
6-terminal 3-position for battery ignition - Often used to control a kill relay for magneto ignition
Used on the XL-Series tractors and Time Cutter zero turn models
Switch rotated to put single terminal at the top
1 page 125KB
88-9830 used on
1993 models 70040, 70042, 70080, 70120, 70140, 71140, 71180, 71181, 71200, 71202, 71203
1994 models 70100, 70141, 71182, 71184, 71191, 71200, 71202, 71213
1995 models 70060, 70141, 70142, 71182, 71184 x 2, 71191 x 2, 71192, 71200 x 2, 71202, 71205, 71213 x 2, 71216
1996 models 70040, 70060, 70081, 70131, 70142, 70183, 71182, 71184, 71185, 71188, 71191, 71192, 71193, 71196, 71201, 71205, 71217, 71218
1997 models 70040 x 2, 70060, 70081, 70131, 70142, 70183, 71185, 71188, 71189, 71190, 71193, 71196, 71201, 71205, 71208, 71215, 71217, 71218, 71219
1998 models 70040, 70041, 70060, 70082, 70084, 71185, 71188, 71189, 71190, 71196, 71201, 71208, 71215, 71218, 71219
1999 models 70044, 70089, 70122, 70171, 70186, 71197, 71198, 71199, 71209, 71220, 71221, 71240, 71254, 70122, 71280
2000 models 70044 x 2, 70089 x 2, 70122, 70171, 71197, 71199, 71209, 71212, 71223, 71225, 71226, 71241, 71280, 71300, 77102, 77104, 77106
2001 models 70044, 70089, 70122, 70171, 71199, 71209, 71223, 71226, 71227, 71233, 71242, 71282, 71301
2002 models 70044, 70089, 70125, 70184, 71199, 71209, 71223 x 2, 71226, 71227 x 2, 71228 x 2, 71233, 71242 x 2, 71283
2003 models 70125, 70184,71199, 71209, 71223, 71227, 71228, 71233, 71242, 71245, 71283
2004 models 70185, 70186, 71199, 71209, 71223, 71227, 71228, 71242, 71243, 71245, 71283, 71285
2005 models 70185, 70186, 71199, 71209 x 2, 71246, 71286, 71427, 71428, 71429
2006 models 70185, 70186, 71209, 71246, 71286
2007 models 70185, 70186, 71209, 71246, 71286
104-2541 used on
2007 models 74406, 74407
2008 model 74406
88-9830 used on
2008 models 70185, 70186, 71209, 71252, 71253
2009 models 70185, 70186, 71252, 71253, 71257, 74433, 74437
2010 models 70185, 70186, 71252 x 2, 71253, 71257
2011 models 70186, 71254, 71255
2012 models 71254, 71255
2013 models 71254, 71255
Tractor Switch IgnitionMagneto ignition with recoil start 225096
