Switch Ignition Battery 111216 replaced by 103990 .jpg 1.0.0
6 Screenshots
1 page from Demystification Guide #492-4509
How to troubleshoot
111216 switch replaced by 103990
5-terminal 3-position key switch for battery ignition
This switch requires a starter solenoid
Tractor Switch Ignition Battery ignition with electric start 111216
(Threads 5/8"-32) 5-terminal 3-position (B-R-I-A-S)
Used 1986 and 1988-1997
111216 5-terminal 3-position replaced by 103990
Tractor Switch Ignition Battery ignition with electric start 103990
(Threads 5/8"-32) 5-terminal 3-position (B-R-A-I-S)
Used 1974-1985 and 1992-1995
Replaces 111216 5-terminal 3-position
103990 5-terminal 3-position available 06/08 $15.61 from RCPW
Napa and Prime-Line replacement switch 7-01892 (9/16" mounting stem)
Stens replacement switch 430-512 (9/16" mounting stem)
Rotary replacement switch 31-1931 (9/16" mounting stem)
Napa and Prime-Line 5-terminal connector body that uses Packard female spade terminals 7-016034 (With terminals and wire leads 7-01910)
Stens 5-terminal connector body that uses Packard female spade terminals 430-206 (With terminals and wire leads 430-223)
Rotary 5-terminal connector body with terminals and wire leads 31-6662
